Switch Stacks
nygenxny123
We have some 3120 swichthes that are currently stacked.
I understand these can be considered 1 virtual switch
But is there anyway to configure a seperate IP address for each switch
so that i can log into an individual switch on the stack?
or even give each switch on the stack its own hostname?
satish_zanjurne
Level 4
Level 4
1.You can log into individual switch of stack
2.For that you do not need seprate IP Address
3.This command is available only from master switch
4.You can access specific stack members by using the session stack-member-number privileged EXEC command. The stack member number range is 1 to 9.
5.Additionally You can access all or specific stack members by using the remote command {all | stack-member-number} privileged EXEC command. The stack member number range is 1 to 9.
6.The stack member number is appended to the system prompt. For example, Switch-2# is the prompt in privileged EXEC mode for stack member 2, and the system prompt for the stack master is Switch.
7.Enter exit to return to the CLI session on the stack master. Only the show and debug commands are available in a CLI session to a specific stack member.
HTH...rate if helpful..
lffrwatson
I dont think you can do this. I know with the Nortel switches this was not an option. The advantage of stacking a switch is having a massive backplane of bandwidth to use between the switches. And logically creating one virtual switch. And also if a switch fails in a stack the others wont suffer.
satish_zanjurne
Level 4
Level 4
