RIP question
The_guroo_2
Level 2
Level 2
guys if two routers are connected and i want that first router shd not recontract rip routing table or interface flapping .....what would be the easiest way to do that.....thanks
Giuseppe Larosa
Hello Khan,
your request is unclear
what do you mean with:
Hope to help
Giuseppe
lffrwatson
are you asking about link flapping affecting rip convergence?
satish_zanjurne
Level 4
Level 4
Are you trying to say, that "first router should not reconstruct/rebuild RIP routing table and because interface/link is flapping that route should not be used " ???
