Switch to switch encryption
Mario Erceg
I need to encrypt trafic between two remote location 1Gb/s. I would like to use Cisco switches with MACsec.
1. Can I use WS-3560CX-12TC-S switches with sfp modules. I found that the switch support MACsec on downlink ports but I'm not sure about uplink.
2. Can I use WS3650-24TS-S switches for same connection?
2. Can I use MACsec if two switches are connected with provider's EoMPLS service?
Best regards
6 Replies 6
Will Kerr
I have successfully done MACSEC on the 3850 over EoMPLS
Thanks.
What IOS and feature set you use?
Please let me know what's your configurations. Thanks.
The Catalyst 3560-C switches support 802.1AE encryption with MACsec Key Agreement (MKA) on downlink and uplink ports for encryption between the switch and host devices.
The switch also supports MACsec link-layer switch-to-switch security by using Cisco TrustSec Network Device Admission Control (NDAC) and the Security Association Protocol (SAP) key exchange.
Link-layer security can include both packet authentication between switches and MACsec encryption
between switches (encryption is optional).
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/15-0_2_se/configuration/guide/scg3560/swmacsec.pdf
2.
Cisco TrustSec NDAC MACsec is supported on switch to switch connections on the 3650 switches.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/37e/consolidated_guide/b_37e_consolidated_3650_cg/b_37e_consolidated_3650_cg_chapter_01110101.html
3.
I found the following for the ASR920, I don't know if the 3560 or the 3650 support this oor something similar"
MACSec (0x88E5) frames can be forwarded over EoMPLS by enabling this command globally:
mac-address-table evc-xconnect l2pt-forward-all
Hello Gpawen,
In a recent project I had t use Port based EoMPLS in order to extend trustsec between C3560 uplinks.
int gi0/20
no switchport
! this is required by port based EoMPLS
xconnect x.x.x.x 5000 encapsulation mpls
any form of EVC based EoMPLS blocked the trustsec negotation because the destination mac address is to be sent to main cpu of an IEEE compliant OSI layer 2 entity like an EVC actually is.
My PE nodes are ME-3600 running IOS XE 15.5.S3.1
Hope to help
Giuseppe
Thanks Gpauwen,
Your link is for IOS 15.0.2. But I found the link about 15.2 IOS for CX switches and it says:
"All downlink ports on the switch can run Cisco TrustSec MACsec link layer switch-to-switch security." This make me confused.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960cx_3650cx/software/release/15-2_5_e/configuration_guide/b_1525e_consolidated_3560cx_2960cx_cg/b_1525e_consolidated_3560cx_2960cx_cg_chapter_01000100.html
This is strange because normally uplink ports are for switch-to-switch communication. I need to use SFP port and can't use downlink ports.
