Inconsistent address and mask
Onrcan91
I've setup this configuration to apply for Standart ACL, i would have allowed accesses some of them but i got an error while configuring Static Routing on Router 0 toward Router 1 that Inconsistent adress and mask.What would you offer ?
try
ip route 172.16.10.0 255.255.255.0 1.1.1.2
Kind Regards
Paul
5 Replies 5
Seb Rupik
What is the static route command you are tying to enter?
Onrcan91
ip route 172.16.10.1 255.255.255.0 1.1.1.2 but i am confused whether i route to network or gateway(172.16.10.1) ?
try
Kind Regards
Paul
As @paul driver points out, make sure you use the subnet ID in your route statements and not an IP address.
Thanks to you as well.
