Switchport security 887VAG router
smith606306
I want to implement port security on one of the fastethernet ports on a Cisco 887VAG but the switchport port-security command is not available.
All i want is to bind a mac address to fastethernet 0, the only command that looks relevant is the 'switchport protected'.
Whats the best way to do this?
interface FastEthernet0
description  Printer
no ip address
end
router-new(config-if)#switchport ?
  access     Set access mode characteristics of the interface
  mode       Set trunking mode of the interface
  priority   Set 802.1p priorities
  protected  Configure an interface to be a protected port
  trunk      Set trunking characteristics of the interface
  voice      Voice appliance attributes
18 Replies 18
Collin Clark
Port Security is not available yet on these routers. Switchport protected will not provide what you are looking for. The only thing I can can think of is to create a MAC ACL and apply it to the port.
Hope it helps.
Thanks Colin
There does not seem to be an option to create a mac address ACl or am i missing something basic?
router-New(config)#access-list ?
  <1-99>            IP standard access list
  <100-199>         IP extended access list
  <1100-1199>       Extended 48-bit MAC address access list
  <1300-1999>       IP standard access list (expanded range)
  <200-299>         Protocol type-code access list
  <2000-2699>       IP extended access list (expanded range)
  <700-799>         48-bit MAC address access list
  dynamic-extended  Extend the dynamic ACL absolute timer
  rate-limit        Simple rate-limit specific access list
GRAWAN1-New(config)# access-list 101 permit ?
  <0-255>       An IP protocol number
  ahp           Authentication Header Protocol
  eigrp         Cisco's EIGRP routing protocol
  esp           Encapsulation Security Payload
  gre           Cisco's GRE tunneling
  icmp          Internet Control Message Protocol
  igmp          Internet Gateway Message Protocol
  ip            Any Internet Protocol
  ipinip        IP in IP tunneling
  nos           KA9Q NOS compatible IP over IP tunneling
  object-group  Service object group
  ospf          OSPF routing protocol
  pcp           Payload Compression Protocol
  pim           Protocol Independent Multicast
  sctp          Stream Control Transmission Protocol
  tcp           Transmission Control Protocol
  udp           User Datagram Protocol
Look at <700-799> :-)
Here's an example
access-list 700 permit 0050.56C0.0008 0000.0000.0000
I just found a command that may help. I'll see what selse I can find. You just want MAC auth correct?
RTR(config-if)#dot1x ?
  authenticator   Configure authenticator parameters
  default         Configure Dot1x with default values for this port
  max-reauth-req  Max No. of Reauthentication Attempts
  max-req         Max No. of Retries
  pae             Set 802.1x interface pae type
  timeout         Various Timeouts
Looks like we can do it with dot1x!
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_usr_aaa/configuration/15-2mt/sec-config-mab.html
Let me know if it helps or not.
Hi Collin,
Mac authentication bypass with dot1x is a working solution but he'll have to install a radius server for this to work.
Does the MAC ACL really filters ipv4 traffic? It doesn't on access switches but i'm not sure if the behaviour is the same on the switch module of the router.
Disabling dynamic mac learning and entering a static MAC  entry for the accepted host would be another solution but I'm not sure it is available on the switch module.
Alain
Leo Laohoo
Filters Using MAC-Based ACLs
Hi Leo,
Isn't this feature only for the wireless part of the router ?
Alain
I created the access list but there seems to be no command to put it on to the interface.
router-New# sh access-list
Bridge address access list 700
    permit 0026.734b.80d0   0000.0000.0000
There is a mac-address command that manually sets the interface mac address but not sure wether that means the actual port or the device connected to it.
router-New(config-if)#?
Interface configuration commands:
  aaa                 Authentication, Authorization and Accounting.
  arp                 Set arp type (arpa, probe, snap), timeout, log options or packet priority
  authentication      Auth Manager Interface Configuration Commands
  auto                Configure Automation
  backup              Modify backup parameters
  bandwidth           Set bandwidth informational parameter
  bfd                 BFD interface configuration commands
  bgp-policy          Apply policy propagated by bgp community string
  bridge-group        Transparent bridging interface parameters
  carrier-delay       Specify delay for interface transitions
  cdp                 CDP interface subcommands
  cmns                OSI CMNS
  content-scan        Content Scan the ingress traffic
  crypto              Encryption/Decryption commands
  dampening           Enable event dampening
  default             Set a command to its defaults
  delay               Specify interface throughput delay
  description         Interface specific description
  dot1q               dot1q interface configuration commands
  dot1x               Interface Config Commands for IEEE 802.1X
  duplex              Configure duplex operation.
  eou                 EAPoUDP Interface Configuration Commands
  ethernet            Ethernet interface parameters
  exit                Exit from interface configuration mode
  flow-sampler        Attach flow sampler to the interface
  help                Description of the interactive help system
  history             Interface history histograms - 60 second, 60 minute and 72 hour
  hold-queue          Set hold queue depth
  ip                  Interface Internet Protocol config commands
  iphc-profile        Configure IPHC profile
  keepalive           Enable keepalive
  l2protocol-tunnel   Tunnel Layer2 protocols
  llc2                LLC2 Interface Subcommands
  lldp                LLDP interface subcommands
  load-interval       Specify interval for load calculation for an interface
  logging             Configure logging for interface
  mab                 MAC Authentication Bypass Interface Config Commands
  mac-address         Manually set interface MAC address
  mace                Measurement Aggregation and Correlation Engine
  macro               Command macro
  metadata            Metadata Application
  mtu                 Set the interface Maximum Transmission Unit (MTU)
  netbios             Use a defined NETBIOS access list or enable name-caching
  no                  Negate a command or set its defaults
  ospfv3              OSPFv3 interface commands
  pppoe               pppoe interface subcommands
  pppoe-client        pppoe client
  rmon                Configure Remote Monitoring on an interface
  routing             Per-interface routing configuration
  service-policy      Configure CPL Service Policy
  shutdown            Shutdown the selected interface
  snapshot            Configure snapshot support on the interface
  snmp                Modify SNMP interface parameters
  source              Get config from another source
  spanning-tree       Spanning Tree Subsystem
  speed               Configure speed operation.
  srlg                Interface Shared Risk Link Group config commands
  storm-control       storm configuration
  switchport          Set switching mode characteristics
  timeout             Define timeout values for this interface
  topology            Configure routing topology on the interface
  transmit-interface  Assign a transmit interface to a receive-only interface
  tx-ring-limit       Configure PA level transmit ring limit
  user-group          Interface-User-group Association
  vrf                 VPN Routing/Forwarding parameters on the interface
  waas                WAN Optimization
  xconnect            Xconnect commands
  zone-member         Apply zone name
In the Document provided by Leo you can see that this MAC ACL is bound to the AP part of the router not to the switching part.
As a workaround I think you should provide a static mapping in DHCP server to this device and then apply a port ACL inbound on the port denying this IP(provided we can  apply an ACL to L2 port on the switch module for this router).
Of course if adding a radius server and configuring it for mac authentication is not a problem for you then you can use the dot1x with mab solution that Collin proposed.
Alain
Alain,
As its a statically assigned address i dont think the DHCP option will work. (we use QIP)
There doesnt appear to be any commands to apply an acl to the L2 Fa ports on the router.
There is no radius server.
I may just have to leave it unsecure
I don't see it how to apply it either, very strange.
Hello Alain,
You should be able to configure MAC-based ACL.
