switchport trunk allowed vlan and switchport trunk allowed vlan add
dazza007
I need some clarification after a fun morning, fortunately there are not too many users this morning!
After bringing half of my network down today while adding a vlan to some trunk ports on the core I am trying to get clarification on the difference in the two lines of config.
interface TenGigabitEthernet2/4
description ***TRUNK LINK***
switchport trunk allowed vlan 51,90,100-110,115,301-312,322,410,510-512,598
switchport trunk allowed vlan add 599,700,710-713,911,912
switchport mode trunk
What is the difference in switchport trunk allowed vlan and switchport trunk allowed vlan add
In order to add a vlan I issued the 1st line command with the added vlan this erased the second line of the config on the port, why would this happen? The switch is a 4900M
Many Thanks
Darren
Hello dazza007,
after a trunk is operational we should use only
switchport trunk allowed vlan add  xx
or
switchport trunk allowed vlan remove yy
to modify the list of allowed vlans on the trunk.
I think tahat the CLI parser should be modified to print a warning when using switchport trunk allowed vlan on a trunk already operational.
Because, it is very common to forget the add keyword in the command almost everyone has made this error.
Hope to help
Giuseppe
6 Replies 6
Hello
Allowed vlan xx = only allows the vlan(s) you specify it will remove any other vlans already being allowed on the trunk if those are also not specified
Allowed vlan add xx = will append vlans to the other vlans already being allowed to cross the trunk
Kind Regards
Paul
Thank you for you time to help me!
when submitting the command switchport trunk allowed vlan add xx should this not add the vlan to the  switchport trunk allowed vlan 1st line on the list I guess by submitting switchport trunk allowed vlan xx, xx,etc this would by default erase the second line of config, as I have seen this morning
Hello
Yes that is correct submitting switchport allowed vlan xx will overwrite whatever is being allowed prior to that statement being submitted
When you enable a trunk all vlans are allowed by default but when you start using the switchport allowed vlan xx  then you are manipulating the all vlans allowed listing whatever that maybe so in a production environment you need to be a bit careful using this switchport allowed command as you could end up doing what you've experienced!
Kind Regards
Paul
Hello dazza007,
or
Hope to help
Giuseppe
Thank you too!
So just to clarify a last point
here is the broken port config
switchport trunk allowed vlan 6,51,100-110,115,301-312,322,410,510-512,598
I submit the command "switchport trunk allowed vlan add 700,710-713,911,912"
and then the config afterwards...
switchport trunk allowed vlan 6,51,100-110,115,301-312,322,410,510-512,598,700
switchport trunk allowed vlan add 710-713,911,912
Why would vlan 700 go onto the 1st line?
Hello
@dazza007 wrote:
Thank you too!
I submit the command "switchport trunk allowed vlan add 700,710-713,911,912"  <- -  then this will join and append to the above
switchport trunk allowed vlan 6,51,100-110,115,301-312,322,410,510-512,598,700 <-- 700 will be allowed by the first line the rest is already allowed
switchport trunk allowed vlan add 710-713,911,912 <- -  then this will join and append to the first line
Kind Regards
Paul
