switchport trunk pruning vlan 2
piotrkrol
hi
knows someone why I have on port 8 on the catalyst WS-C3550-12T
# sh run
interface Port-channel1
switchport trunk allowed vlan 1,1001-1005
switchport mode trunk
interface GigabitEthernet0/1
no switchport
ip address 192.168.0.10 255.255.255.0
interface GigabitEthernet0/2
switchport mode dynamic desirable
speed 10
duplex full
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
spanning-tree portfast
interface GigabitEthernet0/8
interface GigabitEthernet0/9
channel-group 1 mode active
channel-protocol lacp
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
howto get the same settings like on the port 7 ?
Hello Piotr,
somebody probably put this command on the interface to manually prune Vlan 2 off that specific trunk, likely because whatever is connected to interface GigagbitEthernet0/8 does not have a need for VLAN 2.
You can get rid of the command by typing:
no switchport trunk pruning 2
in interface configuration mode.
Does that make sense ?
GP
thanks a lot
