%SYS-2-INPUT_GETBUF: Bad getbuffer, bytes= XXXX, for interface= Ethernet0
Gregory Karidis
I have a 867VAe-K9 with VDSL connection. Last two days i take this error msg:
%SYS-2-INPUT_GETBUF: Bad getbuffer, bytes= XXXX, for interface= Ethernet0.
As a result interface Ethernet0 change state to down.
Diana Karolina Rojas
Hello Gregory?
How many bytes the logs shows you? more than 1500?
Hello Diana, thanks for reply
As you can see in the photo, most 65.533 , and sometimes 65.532
Gregory
