Syslog of nat translations
mmedwid
Level 3
Level 3
My syslogging is only recording messages when - say - I make a chang to the router. But so far I have had no luck in logging that NAT translations that get created.
ip nat log translations syslog
logging facility local6
logging source-interface GigabitEthernet0/1
logging 10.10.10.224
All I see in syslog:
Aug 28 16:51:33 cisco-gw 389: Aug 29 00:47:31.883: %SYS-5-CONFIG_I: Configured from console by admin on vty2 (192.168.55.122)
...that kind of message.
According to Cisco I should be able to just add those four commands. But so far no joy. Did Cisco omit something? Have I missed something? Thanks
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iad_monmain_nat_ps6922_TSD_Products_Configuration_Guide_Chapter.html#wp1048744
mmedwid
Level 3
Level 3
I found the issue. This Cisco Press document is incorrect in its example. In the example they show "logging trap informational". In fact it appears that "logging trap debug" is required.
Enabling Syslog: Example
The following example shows enabling NAT entries into syslog.
Router(config)# logging on
Router(config)# logging 1.1.1.1
Router(config)# logging trap informational
Router(Config)# ip nat log translations syslog
