System returned to ROM by bus error 0x6125DCFC
apkothiyal
                  I have a router cisco 3825, It is being restarted autometically. and gives a message "System returned to ROM by bus error at PC 0x6125DCFC, address 0x15A3C78B" in show ver.
can someone help me, what does it means and what is the reason and how to fix it.
It shows that
     System returned to ROM by bus error at PC 0x6125DCFC, address 0x15A3C78B at 09:49:43 UTC Thu Aug 30 2012
And this address is not valid (compare with "sh region" output).
Crashinfo confirms the crash was due to access to invalid address:
     09:49:43 UTC Thu Aug 30 2012: Address Error (load or instruction fetch) exception, CPU signal 10, PC = 0x6125DCFC
I have decoded the crash traces and it points to bug
     CSCsb61664    cisco 7200 crash by bus error at ipnat_destroy_all_seq_delta_pairs
which was fixed in 12.4(04)T02 and later releases.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
5 Replies 5
Ivan Shirshin
Here is the link on troubleshooting Bus Error crashes:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
I can take a look into the root cause, if you attach "show version", "show region" and crashinfo file (should be in the router flash).
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
                   Hi Ivan, I have been to the link but could not get much inf.
Following is the deatils :
LAN_RTR#show ver
Cisco IOS Software, 3800 Software (C3825-ADVSECURITYK9-M), Version 12.4(4)T1, RE
LEASE SOFTWARE (fc4)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 21-Dec-05 20:56 by ccai
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 3800 Software (C3825-ADVSECURITYK9-M), Version 12.4(3g)
, RELEASE SOFTWARE (fc2)
LAN_RTR uptime is 1 hour, 51 minutes
System image file is "flash:c3825-advsecurityk9-mz.124-4.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.1) with 224256K/37888K bytes of memory.
Processor board ID FCZ1112754F
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
LAN_RTR#
LAN_RTR#
LAN_RTR#
LAN_RTR#
LAN_RTR#
LAN_RTR#
LAN_RTR#show region
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x0FFFFE00  0x0FFFFFFF         512  Iomem  R/W    BCM region
0x2DB00000  0x2FFFFDFF    38796800  Iomem  R/W    iomem
0x60000000  0x6DAFFFFF   229638144  Local  R/W    main
0x60011084  0x61E4457F    31667452  IText  R/O    main:text
0x61E46000  0x638582DF    27337440  IData  R/W    main:data
0x638582E0  0x63C3A03F     4070752  IBss   R/W    main:bss
0x63C3A040  0x6DAFFFFF   166485952  Local  R/W    main:heap
0x80000000  0x8DAFFFFF   229638144  Local  R/W    main:(main_k0)
0xA0000000  0xADAFFFFF   229638144  Local  R/W    main:(main_k1)
Free Region Manager:
LAN_RTR#
Thanks & Regards.
A. Prasad
It shows that
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Thanks ivan.
can u share that ios pls.
If you follow strictly the same branch, it would be 12.4(4)T8:
http://www.cisco.com/cisco/software/release.html?mdfid=279042640&flowid=7529&softwareid=280805680&release=15.1.4M4&relind=AVAILABLE&rellifecycle=MD&reltype=latest
But there are more relevant releases there that you can choose too as 12.4(4)T8 was released at 13-AUG-2007. You would need to check for HW requirements and the features you need.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
