T1/E1 and PRI HWIC
estelamathew
Level 2
Level 2
Hello
I have a 1 port channelized T1/E1 and PRI HWIC (data only) (HWIC-1CE1T1-PRI) Card. I want to know how to configure it, It will be a backup line for the ADSL link which is on static PUBLIC IP through which the remote users are connecting through a Easy VPN.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html
Please answer the below Question
  1. I want to know what configuration should be done for the above card.
  2. Which type of link i should ask for the ISP for this card and will this link can be a backup link for the ADSL which is on static public IP.
  3. After installing the card it will be seen as a which interface
Can anybody route me to the configuration example for the same.
7 Replies 7
estelamathew
Level 2
Level 2
Hello Experts,
I have stuck with this Task, Please anybody can share your expierience with me,
vmiller
Level 7
Level 7
1. Depends on the circuit ordered, If its in the budget order an E1,
2. I would suggest a discussion with your local carrier on what they have to offer. Since this is a backup link, there may be
    some options that save some money.
3. Depends on where in the router its installed.
basic config stuff:
http://www.cisco.com/en/US/docs/ios/interface/configuration/guide/ir_cfg_ser_if_ps10591_TSD_Products_Configuration_Guide_Chapter.html
this just gets the card setup for the link.... with any luck someone next week will pitch in
Thanks miller,
The customer has ordered an ISDN link from the ISP, what type of  ISDN configuration to be done on the router so that incase the active link fails the ISDN link should come for the easy vpn users.
Tx.
Thanks buddy I will read about the ISDN configuration and get back to you incase if i face any issues in understanding.
Definately i will update the rating, As such u deserve the rating.
Fair warning, I'm on vacation next week. I tend to ignore computers then
make sure you get the physical layer configured correctly (reference #1 above).
