T1 multichannel on Cisco 3845 router
dtng99
Hi, can I bound multiple T1 on a Cisco router 3745 or 3845 with T1/E1 serial interfaces? Thanks, David
MarkDeibert1
multiplex
how does multiplex works? new hardware required?
You can bond them using PPP Multilink concept which enables you to bundle multiple links into a single logical bundle and forward traffic on that.
sample config will look like this..
interface Serial 0/0
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial 0/1
encapsulation ppp
ppp multilink
multilink-group 1
interface multilink 1
ip address x.x.x.x y.y.y.y
ppp multilink
multilink-group 1
But do make sure that your remote endpoints also have the same kinda config and the T1s terminating onto the same box...
regds
hi Spremkumar,
thanks for the help with the config. I will put it in use.
David
