T1 Multilink ppp failure
Hi everyone,
I am having troubles to enable 3xT1 ppp multilink between a 3745 and a 2921 with WICs, through a ISP WAN cloud. both sides are taking clock from ISP.
Today this connection is made between a 3745 on each side, and in this scenario, multilink ppp 3xT1 is working. however, since i have to replace one 3745  for an 2921, bundle goes down
i will paste both configs parts if anyone have any idea whats going on...IPs are shown as example, are not the real ones
3745:
no network-clock-participate slot 1
no network-clock-participate slot 2
no network-clock-participate slot 3
no network-clock-participate slot 4
interface Multilink1
description to_2921_router
ip address 1.1.1.1 255.255.255.252
ppp multilink
ppp multilink group 1
interface Serial0/0
no ip address
encapsulation ppp
ppp multilink
interface Serial3/0
no ip address
encapsulation ppp
ppp multilink
interface Serial4/0
no ip address
encapsulation ppp
ppp multilink
new 2921:
no network-clock-participate wic 0
no network-clock-participate wic 1
controller T1 0/0/0
cablelength long 0db
channel-group 1 timeslots 1-24
controller T1 0/0/1
controller T1 0/1/0
description PPP_to_3745
ip address 1.1.1.2 255.255.255.252
ip nat inside
ip virtual-reassembly in
ppp multilink
interface Serial0/0/0:1
no ip address
ip nat inside
encapsulation ppp
ppp multilink
interface Serial0/0/1:1
no ip address
ip nat inside
encapsulation ppp
ppp multilink
interface Serial0/1/0:1
no ip address
ip nat inside
encapsulation ppp
ppp multilink
here is the output command for eache Serial interface 2921 router
Serialx/x/x:x is up, line protocol is down
  Hardware is DSX1
  MTU 1500 bytes, BW 256 Kbit/sec, DLY 20000 usec,
     reliability 192/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP REQsent, multilink Closed, crc 16, loopback not set
Multilink1 is down, line protocol is down
  Hardware is multilink group interface
anyone have any idea why is not going up this serials?
my guess is that something is going on with "multilink bundle-name authenticated" command.
thanks in advance!
9 Replies 9
Richard Burts
While the command multilink bundle-name authenticated is a command found on the new router and not on the older router it may seem to be a candidate for what is causing the problem. But I do not think that this is really the issue. That command is inserted into the config automatically in many newer versions of IOS and I doubt that it is the real cause of your problem.
Perhaps you could post the output of show controller for the serial interfaces on the 2921 and we might get some insight from that?
Rick
Rick
Richard,
Here is the output for show controller from the serial interfaces on the 2921...
T1 0/0/1 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
--More--                             No alarms detected.
--More--                             alarm-trigger is not set
--More--                             Soaking time: 3, Clearance time: 10
--More--                             AIS State:Clear  LOS State:Clear  LOF State:Clear
--More--                             Version info FPGA Rev: 08121917, FPGA Type: PRK4
--More--                             Framing is ESF, Line Code is B8ZS, Clock Source is Line.
--More--                             CRC Threshold is 320. Reported from firmware  is 320.
--More--                             Data in current interval (93 seconds elapsed):
--More--                                0 Line Code Violations, 0 Path Code Violations
--More--                                0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
--More--                                0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
--More--                             Total Data (last 24 hours)
--More--                                3703 Line Code Violations, 9 Path Code Violations,
--More--                                0 Slip Secs, 1 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
--More--                                0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 82821 Unavail Secs
--More--                           T1 0/1/0 is up.
--More--                             Applique type is Channelized T1
--More--                             Cablelength is long 0db
--More--                             Data in current interval (86 seconds elapsed):
--More--                                3698 Line Code Violations, 7 Path Code Violations,
--More--                                0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 82716 Unavail Secs
--More--                           T1 0/1/1 is up.
--More--                                4207 Line Code Violations, 2 Path Code Violations,
--More--                                0 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
--More--                                1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 82501 Unavail Secs T1 0/0/1 is up.
Christian,
This probably has little to do with your issue, but why do you have "ip nat inside" on the mlp interface on the 2921? You should remove that as well as on all of your serial interfaces.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John,
As you didnt see present ip nat inside in old router, might confused you. However, in old router already exists 'ip nat inside' and 'ip virtual-reassembly in' on serial as well as on multilink config.
I forgot to paste it in first post.
so my guess is that is not affecting this issue.
paolo bevilacqua
Update IOS and check again.
What i didnt mention is that
3745 wic card model is WIC-1DSU-T1-V2
and 2921 ISR wic card model is HWIC-2CE1T1-PRI
shall you see any problem with this?
One would need to obtain much more information to say.
You should open a TAC case.
Thanks for posting the output of show controller as I requested. What jumps out at me from the output is this
In the 24 hour period the controller sees the circuit as available only 3579 seconds. If the circuit ran clean on the old connection then I believe that this suggests that there is a problem with the cards (or less likely with the router or with the code that it is running). Can you tell us what version of code is running on the 2921?
One article that I looked at suggests that this card does channelized T1 and that including the parameter for unframed for the channel group might be helpful.
Rick
Rick
Richard,
Thanks for your response.
The version of code that is running on the 2921 is the c2900-universalk9_npe-mz.SPA.152-4.M2.bin
thanks in advance
