T3 Controller details
shrikant4u
Networkers/Guru's
Can any one please help me to understand difference/ significance of these two commands?
Router:  Cisco 7200
Card :    Enhanced 1 port T3 multichannel Port adapter, 1 port  /   PA-MC-T3-EC
04-B#sho controllers t3 6/0:28 tabular
T3 6/0 is up.
  T1 28 is up
  timeslots: 1-6,8,10-24
  FDL per AT&T 54016 spec.
  No alarms detected.
  Framing is ESF, Clock Source is Internal
  INTERVAL      LCV   PCV   CSS  SELS   LES    DM    ES   BES   SES   UAS    SS
  10:57-11:02     0     0     0     0     0     0     0     0     0     0     0
  10:42-10:57     0     0     0     0     0     0     0     0     0     0     0
  10:27-10:42     0     0     0     0     0     0     0     0     0     0     0
04-B#sho controllers t3 6/0:28 remote performance tab
T3 6/0 is up.
  T1 28 - Remote Performance Data
  10:59-11:03     0     0     7     0     0     0     7     0     0     0
  10:44-10:59     0     0    27     0     0     0    27     0     0     0
  10:29-10:44     0     0    28     0     0     0    28     0     0     0
We have Channelised T3 of which 1 T1 channel (chann 28)  is broken up further for Frac T1 (256k) circuits.  One of those Frac T1  circuit  is having issues.Telco keeps insisting nothing wrong on there network.
paolo bevilacqua
Take show controllers T1, show interface on the router that have issues.
I'm not able to get serial int view in tabular form
04-B#sho controllers serial 6/0/28:9
Serial6/0/28:9
Hardware versions:
firmware version: 0x01070000
iofpga version: 0x00010002
freedm version: 0x00000000
temux version: 0x00020003
subrate fpga version: 0x00010004
liu version: 0x00000000
Rommon version: 0x00020000
rx_int_count 1523448654, tx_int_count 287049240
pak_move_failed 0 rx_idb_null_count 0
tx_count 0, output_qcount 0
xoff_word 0x387E0068, actual word 0xF57D7775,
bitword_mask_hi 0xC ,bitword_mask_lo 0x3
rtn_code_hi 0x0, rv_hi 0x4
rtn_code_lo 0x0, rv_lo 0x1
XOFFHI R=0 V=0
XOFFLO R=0 V=0
bytes_in_tx_lo  44, bytes_threshold_lo 1920
bytes_in_tx_hi  514, bytes_threshold_hi 1920
unmatched_anyphy 0 noshim 0
interface Serial6/0/28:9 is not master_link
fs_safe_start_fail 0 fs_safe_start_pass 0
Max Output enqueued 194, queue_drops 21407
safe_str_tail 101, safe_str_head 101
fastsend is 0x381D14, safestart is 0x383558
oqueue 0x16D025C, oqueue_dequeue 0x16D1288
write_addr 0xE5710000
rx_dma_bd_index_addr 0x38376240, rxr 0xE5704000, rxr_shadow 0x8F45AF0
present valid buffer pointer is 0x418138, in shadow 0x38814100
Tx interrupt 0x383624
ci_table 0x906E484
ctx 0x85AC0B8
oir_on_wait:FALSE no_intfs_reset:0x00000000
Autodnr Lock fail 0 Autodnr Process Failures 0
shadow_tx_status 0x387E0064 Active VCs/Port I port 24 II port 0
IPC stats for slot 6
0x867D8A4: ipc_rx_pkt_drops 0, ipc_tx_pkt_drops 0
pa_ipc_restart_cnt 0, pa_ipc_keep_restart 0
No Keepalive 0 ECC Single bit errors 0
oqueue_interleave_dequeue 0x16D18A0, QOS classify 0x16D0064
Do you want to solve the problem, or go after the way the output is displayed ?
Paolo  ...sorry about that
Config for controller  and show interface on both side  is attached.
