t3/E3 card
mburguk1000
I have a new 3845 router with a T3/E3 card in it. The card is not listed when you do a show interfaces but is listed when you do a sh ver or sh hardware.
Could someone please tell me the best way to configure this card so it shows as serial port
Many Thanks
tdrais
Level 7
Level 7
You have to put in a channel group and map the channels to the channel group. It will create the serial interface at that time. Depending on the card you may be able to define multiple serial interfaces and map them to multiple channel groups.
