Router to Router DDR problem
mohdrafeeque
Dear All,
I have two routers router1 and router2, I connect both of them using modem on async interface. my problem is, most time it will not work; even after reset modem of both side. May be some time it will work, but after some time it will automatically disconnect. When users using this line, it may be working only three or four min then disconnect. I mean no stable at all.
Router1 running configurations
hostname router1
username router2 password 0 cisco
no aaa new-model
ip subnet-zero
ip cef
chat-script default ABORT ERROR BUSY "NO ANSWER" "" "ATDT\T" TIMEOUT 60 CONNECT \C
interface serial/7
physical-layer async
description connected to router2
no ip address
encapsulation ppp
dialer in-band
dialer rotary-group 1
dialer-group 1
async mode dedicated
interface dialer1
ip address 172.16.22.1 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 3600
dialer map snapshot 1 name xxx broadcast
dialer map ip 172.16.22.2 name router2 modem-script default boroadcast 041234567
dialer hold-queue 10
snapshot server 15 dialer
no cdp enable
ppp authentication chap
router rip
network 172.16.0.0
ip classless
ip route 172.16.12.0 255.255.255.0 172.16.22.2
dialer-list 1 protocol ip permit
router2 running configurations
username xxx password xxx
mmi polling-interval 60
no mmi auto-configure
no mmi PVC
mmi snamp-timeout 180
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
chat-script default ABORT ERROR ABORT BUSY ABORT "NO ANSWER" "" "ATDT\T" TIMEOUT 60 CONNECT \C
interface f0
desc connect to router1
ip address 172.16.12.1 255.255.255.0
speed auto
Interface s0
description connected to router1
no ip address
encapsulation ppp
dialer in-band
dialer rotary-group1
dialer group1
Interface dialer1
ip address 172.16.22.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer map snapshot 1 name router1
modem-script default broadcast 026345678
dialer map ip 172.16.22.1 name router1 modem-script default broadcst 026345678
dialer-group 1
snapshot client 15 360 suppress-state change-update dialer
no cdp enable
how can I make my connection stable; please help me
cisand2002
hello Mohd,
can you add to router 2
and to router 1
interface dialer1
dialer group1
I am suspecting that connection disconnect because of idle-timeout expire.
Can you send us a "sh interface dialer1" output with interval of 30 sec ?
please also use "debug dialer" and send output when line disconnect.
cisand
hi cisand
I am sorry to left some commands in router2; this also included in router2
router ospf1
log-adjacency-changes
network 172.16.0.0 0.0.255.255 area1
cdp timer 10
line1
timeout login response 300
modem inout
modem autoconfigure type usr_sportster
stop bit 1
speed 115200
flow control hardware
I am ready to send you dialer output and debug output; but you know some time modem hesitates to dialing; even after I reset modem of both sides no progress. After I try more time; one time it may be connect; it will stay only a few minutes then disconnect. when I get connection; PING response time will be low; it increases and disconnecting. That is the problem I am facing.
slayerhawk
I have a similar issue. I have a 1750 dialing into a 3640. The 1750 dials in and connects. I can ping the 170.1.1.16 from the 1750 and my laptop. I can ping internal hosts without a problem from the 1750. I have a laptop attached to the router behind a cisco hub. I can ping the 1750 from the laptop but no further. Please help.
Steve
There are a couple of things in your post that I am not clear about. I note that the Ethernet 0 configures async 5 as backup interface. So what does it take to get the router to dial. I see an interface dialer 1 but nothing that relates to this. I see a floating static default route using async 5, but I do not see any other source of routing information.
I suspect that the problem may be that you have a route for how to get traffic out, but that the remote destinations do not have a working route to get traffic back to you over the dialer.
As a side note: your problem seems to be different from the problem in the original post. You probably would have done better to have started a new thread than to append your problem to a previous thread.
Rick
Rick
