Tacacs config on WAAS device
gopal_4476
All,
we have tried to configure AAA on WAAS (Wide Area Application Services)device. we have applied all the aaa commands on waas device and made necessary configs changes on tacacs server as well.
WAAS device is speaking to tacacs server and I am able to login to waas device through tacacs id, the problem here is when i tried to go to enable mode on waas device its not accepting my tacacs password instead its taking local password.
I am sure i am missing something here, can any one throw some lights here to solve this issue as this is very ciritcal activity for me.
Many thanks in advance and pasted AAA configs applied on WAAS device.
authentication login tacacs enable primary
authentication login local enable secondary
authentication configuration tacacs enable primary
authentication configuration local enable secondary
aaa accounting commands 15 default start-stop tacacs
tacacs host **.**.**.* primary
tacacs key ******
Gopal
7 Replies 7
mahmoodmkl
Level 7
Level 7
u need to add the below line in u r config
aaa authentication enable default group tacacs+
Mahmood
Hi Mahmood,
Thanks for your reply, I have applied the given command and its not accepting.
Its Cisco WAAS router ruuing below ios.
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2007 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.0.13 (build b23 Sep 8 2007)
Version: oe7341-4.0.13.23
Compiled 18:41:02 Sep 8 2007 by cnbuild
System was restarted on Sat Apr 12 13:49:26 2008.
The system has been up for 5 weeks, 6 days, 20 hours, 37 minutes, 16 seconds.
Gopal
can u try this
authentication enable tacacs enable primary
Mahmood
can u try this
Mahmood
Yes, tried this. Nothing is working.
Gopal
Gopal
Pretty clearly the problem is that it is requiring the local enable password because there is no configuration in aaa for authenticating enable. So we need to find the correct syntax to use. Can you post the output that you get from online help?
- go into config mode.
- type aaa authentication enable ?
- if it shows default as an option then type
aaa authentication enable default ?
Perhaps this will help us figure what syntax it is looking for.
Rick
Rick
Hi Rick,
i am able to login via Telnet but unable to login via GUI.
Gopal
