Tacacs configuration for N540 router
poojaryp1974
can someone please share me tacacs configuration for N540 router.
Prash
Mark Elsen
     - FYI : https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/system-security/76x/b-system-security-cg-76x-ncs540/configuring-aaa-services.html#task_C76D235CC2BC4B8887E482D2E66656B8
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I noticed that you asked this question before, which implies that you still have not found a solution ? What commands are available on your N540 ? Can you configure 'aaa new-model' ?
Blue_Bird
Hello poojaryp1974 ,
Tacacs Summary Example:
! OOB TAC
tacacs-server host 123.100.100.186 port 49
key lm51
tacacs-server host 123.100.100.187 port 49
key lm51
aaa group server tacacs+ tacgrp
server 123.100.100.186
server 123.100.100.187
aaa group server tacacs+ eem
aaa authorization exec tacauthen group tacgrp local
aaa authentication login taclogin group tacgrp local
line console
login authentication taclogin
timeout login response 30
timestamp
exec-timeout 0 0
session-timeout 15
vty-pool default 0 99 line-template console
Reference: https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5xx/system-security/76x/b-system-security-cg-76x-ncs540/configuring-aaa-services.html#task_C76D235CC2BC4B8887E482D2E66656B8
Best regards
******* If This Helps, Please Rate *******
