Do we need to purchase license for upgrading ISR 4331 throughput ?
Herman2018
Level 3
Level 3
Hi, good day, can anyone please advise whether need to purchase performance license to upgrade ISR 4331 throughput from
default 100M to 300M
? Thanks in advance!
You're welcome @Herman2018
ISR4331 Throughtput From
100M to 300M: FL-4330-PERF-K9
Best regards
M02@rt37
Hello @Herman2018,
You need Performance License. See Table 4 here: https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
Specifications of Cisco 4000 Family Integrated Services Routers
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Best regards
Thanks M02@rt37 for your kind advice! Is there a part number of this performance license? Thanks.
Best regards
istvan-marlok
And do we need a HSEC license also for the throughput upgrade? What happens if I only buy FL-4330-PERF-K9? Throughput will be limited at 250Mbps?
Thank you!
