Tacacs on Alternate Port
laneygypsy
Having problem on with tacacs server commands for alternate port.
I do not have the available commands on my router what is the trick?
c1900-universalk9-mz.SSA-eng-sp-153-3.M1.bin
ipbase ipbasek9 Permanent ipbasek9
ISSUE:
This is what i get for commands:
router(config)#tacacs-server host 1.1.1.1 ?
<cr>
This is what I NEED to get:
key                                per-server encryption key (overrides default)
nat                                To send client's post NAT address to tacacs+ server
port                               TCP port for TACACS+ server (default is 49)
single-connection         Multiplex all packets over a single tcp connection to server (for CiscoSecure)
timeout                         Time to wait for this TACACS server to reply (overrides default)
<cr>
You are using the legacy config. Try the new config-style:
core1(config)#tacacs server ISE1
core1(config-server-tacacs)#?
TACACS server sub-mode commands:
address Specify ip address for tacacs server
exit Exit from TACACS server configuration mode
no Negate a command or set its defaults
send-nat-address To send client's post NAT address to tacacs+ server
laneygypsy
Actually I did not realize but I needed to add "aaa new-model" prior to adding the tacacs servers.
Which actually seems kind of strange, and is not documented anywhere.
So....
aaa new-model
then
tacacs-server host x.x.x.x port 40109
