Tarrfic-shape or Policy-Map
carloskuontay
Hi Experts! I am trying to configure bandwidth control (only ICMP) in a ROUTER but in "both" ways. From PCA to PCB I want to configure 200K, and from PCB to PCA I want to configure 400K. This configurations are done because I want to avoid excessive traffic that can be increase the process of my router. There is other kind of traffic passing through these interfaces must not controlled:
PCA ----> G1/1 ROUTER G2/2 ----> PCB
PCA <---- G1/1 ROUTER G2/2 <---- PCB
1.- What is better? traffic-shape or policy-map?
2.- If I use traffic-shape, in wich interface do I must apply?
3.- If I use policy-map, in wich interface do I must apply?
4.- Is the following configuration correct?
PCA=10.10.10.10, PCB=20.20.20.20
access-list 110 remark LIMIT PCA to PCB
access-list 110 permit udp host 10.10.10.10 host 20.20.20.20 eq snmp
interface G2/2
traffic-shape group 110 200000
access-list 120 remark LIMIT PCB to PCA
access-list 110 permit udp host 20.20.20.20 host 10.10.10.10 eq snmp
interface G1/1
traffic-shape group 120 300000
Normally, traffic-shape is used in the outside of the interface, but with this, there is passing a lot of traffic to the router. With "policy-map" is more efficient? Can you send me an example please?
Thanks for your help!!!
Istvan_Rabai
Level 7
Level 7
Hi Carlos,
Traffic-shaping can be implemented in the outbound direction only.
So you must configure traffic-shaping on G1/1 and on G2/2 as well, if you want to implement it in both traffic directions.
The policy-map configuration is the newest method of configuring QoS.
Personally I would prefer to use the policy-map method, because it always separates traffic classification from the action taken on the traffic class, and this creates a more structured and clear configuration.
In addition to this, class-maps and policy-maps, once created, can be reused in other QoS configurations within the same router, which makes configuration quicker and the probability of configuration errors decreases.
Cheers:
Istvan
Thanks Istvan! Do you have an example of the configuration of policy-map?
Hi Carlos,
Access-lists:
access-list 120 permit udp host 20.20.20.20 host 10.10.10.10 eq snmp
Classifying traffic:
class-map PCA-TO-PCB
access-group 110
class-map PCB-TO-PCA
access-group 120
Definition of QoS actions:
policy-map PCA-TO-PCB
class PCA-TO-PCB
shape average 200000
policy-map PCB-TO-PCA
class PCB-TO-PCA
shape average 300000
Applying QoS policies to the interfaces (in this case in the outbound direction):
interface Gig2/2
service-policy output PCA-TO-PCB
interface Gig1/1
service-policy output PCB-TO-PCA
Cheers:
Istvan
