TCP MSS CLAMPING issue
james_72
Dear experts,
I have tcp adjust-mss configured on an internet link with an ISP like following:
interface GigabitEthernet0/0/0
 description internet WAN link
 ip address x.x.x.x 255.255.255.252
 ip tcp adjust-mss 1436
During DDOS attacks our firewall starts SYN challenge (acting as a proxy) and I see sniffing traffic over the WAN link that MSS is not adjusted accordingly from the router.
I suspect the current Cisco implementation does not change MSS because the syn-ack does not contain the MSS option.
Questions:
1) do you know if this is the correct behavior ? I do not find anything official (ASR1k IOS 16.3.7) on www.cisco.com... in case please share the URL
2) any suggestion if there is a way to set the MSS on ASR1k when not received in the syn-ack from the server...
The impact is that then the client do not reduce the segment and at the end the issue come once certificate is being exchanged in the TLS session...
Thanks in advance
Cheers
  Which technology does your WAN is formed? Does it has any tunnel like GRE, DMWPN, SDWAN, etc?
For sure the Syn and Ack will not have TCP MSS. Syn and Ack are only a kind of "hello" in order to devices start talking. TCP MSS is expected to see on the header of TCP packet.
https://xvirt.ink/2018/02/21/tcp-syn-packet/
yes it is GRE for the anitDDOS provider.
As far as I know TCP MSS is negotiated at syn - ack, please see here:
https://learningnetwork.cisco.com/s/question/0D53i00000SnqXL/tcp-why-tcp-choose-lower-mss-
