TCP to X.25 Translation
MortezaSoltani
Hello everybody
Im using Cisco router as Tcp to X.25 translator. In Tcp to X.25 conversion during X.25 call setup
Cisco router acts as a XPAD device and send call request along with CUD 0X01000000 which
shows source device (Cisco Router) is a PAD device .
Our X.25 remote device just accept X.25 calls from X.25 source , not XPAD so it rejects the call.
How we can force Cisco router to act as a pure X.25 device (not PAD) or send call request without
XPAD CUD.
Leo Laohoo
Are you using ALP (AirLine Protocol set) or MATIP (Mainframe To IP)?
paolo bevilacqua
You can set the value that you want - cud option in translate command.
Hi again,
one thing more.
CUD option just adds cud string to call setup and doesn't omit it.
Nov 24 08:34:08.747: Serial0/0/2: X.25 O R1 Call (17) 8 lci 1
Nov 24 08:34:08.747:   From (4): 8000 To (4): 4003
Nov 24 08:34:08.747:   Facilities: (0)
Nov 24 08:34:08.751:   Call User Data (8): 0x01000000 (pad)
   0:                   10010B44 40038000          ...D@...
     8: 00010000 00746573 74                 .....test
Nov 24 08:34:08.839: Serial0/0/2: X.25 I R1 Clear (5) 8 lci 1
Nov 24 08:34:08.839:   Cause 0, Diag 32 (DTE originated/Packet not
allowed)
      0:            100113 0020                    ....
Nov 24 08:34:08.839: Serial0/0/2: X.25 O R1 Clear Confirm (3) 8 lci 1
       0:                   100117                     ...
Thx & rgrds
You set the value that you want, or null.
