Telnet command not working on ASR Routers
palani2010
Telnet command not working on ASR Routers.
Could some one help us how to check the destination servers listening port over TCP on ASR devices
marce1000
        - What error are you getting ?
 M.
balaji.bandi
Make sure you lines has below line to use telnet :
line console
  transport output telnet
If you like to check remote device listing port or not , use can also use windows tools to test
https://learn.microsoft.com/en-us/sysinternals/downloads/psping
example to test 443 port :
c:\Tools\PSTools>psping.exe -i 0 -n x.x.x.x:443 (x.x.x.x is the IP address you want to check)
Make sure no FW between device and target server. (if any FW make sure that port is open to test)
BB
