Telnet not working on cisco router 3925
gmaghesh81
I have one router 3925 equipment DIRECTLY connected to the Router that needs to be accessed by telnet port 23.
Please find the attached config details.
Thanks in advance,
Maghesh
Hello, if your access list 23 does not permit your subnet you are telnetting from, you will be denied access.
Ip access-list standard 23
Permit 10.142.x.x 0.0.255.255
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
6 Replies 6
Bilal Nawaz
Hello, I cannot see the attachment because I'm using a mobile device, but have you configured a password under the VTY line?
Conf t
Enable secret xxxxxx
Line vty 0 4
Password xxxxxxx
Login
Where xxxxxx is your password you set.
Hope this helps
Firuz Azimov
line vty 0 4
access-class 23 in
privilege level 15
password redknee
login authentication local_auth
transport input telnet ssh
Is you connect from
10.10.10.0 0.0.0.7 subnet ?
Can you delete password redknee and login authentication local_auth
For example
line vty 0 4
access-class 23 in
privilege level 15
login local
Also you need set privil. password
enable secret XXXXXXX
This is simple and must work.
I am not sure about :
password redknee
What is the aaa configuration please?
Hope this helps
I just want to do telnet from my network(10.142.x.x)
I don't use the 10.10.10.0 0.0.0.7 subnet ?
Current conf  :
line vty 0 4
access-class 23 in
privilege level 15
password cisco
line vty 5 15
access-class 23 in
privilege level 15
password cisco
scheduler allocate 20000 1000
saved the config & reload the router but still the same issue.
Mahesh
Hope this helps
Hi Maghesh,
Bilal is righ here, you need to put the acl as mentioned above by Bilal.
Hope it will resolve your problem.
