02-09-2015 08:48 AM - edited 03-05-2019 12:45 AM
Hi Friends,
i am trying to change an interface to act like console port when i telnet to it !
how can i enable the terminal monitor by default on it?
thanks
02-09-2015 10:05 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Often you only need the interface to have an IP.
02-09-2015 01:08 PM
hi Joseph,
i am trying to use DDR link to Create an out of band connection .. i know how to configure the DDR correctly with IP Addresses but i was wondering if we can do it in different way that don't required IP Address and provide connection very similar to the Console for example the Terminal Monitor will be ON.
02-09-2015 05:42 PM
Disclaimer
Posting
It has been many, many years since I've needed to configure DDR. However, unlike a console, which has a dedicated port, telnet, I believe, needs an IP. Now, it doesn't have to be the interface your connection physically comes in on, but it does need to be reachable by the telnet client.
BTW, some routers have an aux port that you can configure for OOB access, and when you do, I don't believe they require an IP address. For those, you would use a dial-up terminal client. (Believe some software can do both functions.)
