Tengig interface not showing
Sanjay Shaw
I am using a Cisco ME 3800 switch with 24 Gig and 2 Tengigabit interface. But after configuring the Tengig int with ip add and negotiation it is no know visible in the switch. Instead TenGig I am seeing two (Gi0/1 and G0/2). Not even showing the Tengig in the running config. PFA.
Hope any one in the forum has the solution to get the tengig interface in the running config visible.
Sanjay Shaw
am using a Cisco ME 3800 switch with 24 Gig and 2 Tengigabit interface. But after configuring the Tengig int with ip add and negotiation it is not know visible in the switch. Instead TenGig I am seeing two (Gi0/1 and G0/2). Not even showing the Tengig in the running config.
Leo Laohoo
I'm in deploying ME3800X.  My interfaces (without SFP/SFP+) are known as "TenGigabitEthernet0/1" and "TenGigabitEthernet0/2".
Hi Leo,
Thanks for ur reply.
If I am not wrong here I have to use SFP+ for Tengig interface so that the media type could be recognized.
10/100/1000BaseTX SFP will not work in Tengig port.
After inserting SFP+  modules this got detected.
