Convert a T1 connection to Ethernet?
wilddoktor-sp
I need to convert a T1 connection to Ethernet, and then plug the Ethernet into a vendor-configured SonicWall TZ205.  Seems like there should be a simple "media converter" type box that could do that for me, but I haven't found anything like that.
I have a spare cisco 1841 with a dsu/csu WIC...but am a complete cisco novice.
Is there a way to use that 1841 to accomplish my goal? Or, does anybody know of a media converter box that would do it?
Thanks!
9 Replies 9
mvsheik123
Level 7
Level 7
Not sure how far ths works for your scenario. Found this thru 'google' search..
http://www.rad.com/10/T1-Serial-and-Ethernet-Interface-Converter/3214/
all the best.
Thx
MS
Bill
I am not sure that I completely understand your situation and your requirements, but I am thinking that if on your 1841 you turn off ip routing, and then enable bridging on both the T1 interface and an Ethernet interface that the 1841 should convert between the T1 serial and the Ethernet.
Rick
Rick
Richard, will "no ip route" actually work on this 1841?
If so, any idea what commands I'd use to bridge the serial0/0/0 and fa0/0 interfaces?
Bill
I have not had any reason to test the command on an 1841. But I have used it on other Cisco IOS routers and it worked for them. I have no reason to believe that it will not work on an 1841. If you do try this please post back with the results.
The commands are quite simple. You start by configuring bridge 1 protocol ieee. After the bridge group is established then you just configure bridge-group 1 under both Ethernet and serial interfaces.
You can use this link to see an example of configuring transparent bridging between Ethernet and serial interfaces.
http://www.cisco.com/en/US/tech/tk331/tk660/technologies_tech_note09186a0080094471.shtml#ex3
Rick
Rick
Thanks for the info Richard; seems simple enough. I'm looking over the link and not exactly sure what example to zoom in on. It's serial T1 on one side and ethernet on the other side, but I don't know if that means "frame relay" or what.
I've also read elsewhere that encapsulation on the two interfaces may be different. Thoughts on that?
Bill
focus on example 3 which is an example with a simple serial interface and an Ethernet interface which will be what you are trying to do. At least that is what I assume that you are trying to do. Perhaps we should clarify what kind of T1 is this and what kind of traffic is it carrying?
I am not sure that I understand the question about different encapsulation. Clearly the serial line will use some serial encapsulation and the Ethernet will be using Ethernet encapsulation. So yes each interface is using encapsulation that is different from the other. This is not a problem for what you are trying to do.
Rick
Rick
So does this look correct, then? I did a sh run and copied part of it:
interface FastEthernet0/0
description Ethernet to Sonicwall
no ip address
duplex auto
speed auto
bridge-group 1
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
description T-1 from provider
no ip address
bridge-group 1
ip classless
ip http server
no ip http secure-server
control-plane
Bill
This looks (mostly) pretty good. I do not see the no ip routing command. Since there are no IP addresses in the config perhaps it does not matter. But I would feel better if the config included the no ip routing command.
Also I will comment that this configuration seems to suggest that you are connected to an external CSU/DSU and that the encapsulation of the link is HDLC(the Cisco variety). If those assumptions are correct then the config is good. If not then some adjustment may be needed.
But the most important parts (specifying the bridging protocol and applying bridge-group to the interface) are looking good.
Rick
Rick
Ugh. As it finally turns out, the company with the sonicwall was expecting us to have a router, not a converter.
So we are right now configuring the 1841 as a router, setting up the serial port and the fa0/0 port.
Should be up and running in a few minutes, now that we know what's expected of us!
Sheesh.
Richard, I appreciate your help and will mark your last reply as the answer. :-)
