test aaa auth on cisco asr 1000
Ibrahim Jamil
Level 6
Level 6
Hi Guys
how to test the aaa  on cisco asr 1000 ?i wana test some user account to a cisco acs
thanks
5 Replies 5
mahmoodmkl
Level 7
Level 7
it is same like how u do on other devices
let us know wht is u r concern
the syntax is totaly different the IOS is IOS-XE, i tried , but i fail that is why i post
thanks
Hi Jamil,
May be you could try
test aaa group {group-name | radius} username passwordnew-code [profile profile-name]
Hope that helps
Najaf
the syntax is below
asr-1#test aaa authentication ?
  attrlist  aaa attribute list name
The below output is form one of my devices and the syntax is same.
aaa authentication login vty group radius local enable
aaa authentication login console group radius local enable
aaa authorization console
aaa authorization exec default group radius if-authenticated
aaa authorization exec console group radius if-authenticated
aaa authorization exec vty group radius if-authenticated
aaa authorization network default group radius if-authenticated
aaa accounting exec default start-stop group radius
aaa accounting exec console start-stop group radius
aaa accounting exec vty start-stop group radius
aaa accounting network default start-stop group radius
