Test port status at router
interfacedy
Folks:
I want to use a router at eve-ng as a server to test each port status and its reachability in the router in a lan environment. Do you think if this is possible? Thanks
i may blog but not able to find for now.
you can use below guide :
https://www.petenetlive.com/KB/Article/0001432
BB
balaji.bandi
sure that works if that has the correct external facing allocated to Router. use Cloud0 interface.
BB
Thank you for your reply. Can you tell a little bit more how to do it? or send a link.
BB
interfacedy
Thank you
