Testing leased line
ncnaveen_arasu
Hi friends,
When ever we have commissioned a new physical WAN link we will be assured that for example, a bandwidth of 100Mbps from an ISP. How do we test the link wether it is capable of passing a traffic of 100Mbps other than putting a load on the link via ping command. Please let us know the way how can we put the load to test the links full capability.
Thanks in advance,
Naveen
Richard Burts
Doing a single ping over the link is not a good test. For one thing processing ping and generating a response is more a test of the processor which generates the response than it is a test of the circuit.
Another issue to consider is that a single stream of traffic is not a good test of the circuit. It is a much better test if you can arrange for multiple streams of traffic.
It would be a better test of the circuit capacity if you could use a tool such as smart bits to generate the traffic rather than depending on a host connected to the router or depending on the router itself to generate test traffic.
Rick
Rick
do you have a link for this programs?
mfurnival
Level 4
Level 4
If hardware based packet generators are out of the question you can use iperf which gives a good indication of what bandwidth you are getting. One end runs a server connection and the other end acts as a client and they stream traffic between themselves and tell you what bandwidth you are getting. There are lots of options such as modifying TCP window size etc. The server / client can be run on Windows or Linux.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
For quick verification of provisioned bandwidth, I've used a software based traffic generator that can generate traffic faster than the nominal capacity of the the link.  For example, if I send 120 Mbps across a nominal 100 Mbps, I expect 100 Mbps to be received on the other side.
