TESTING WAN INTERFACES
amouralamein
I have been testing 2610 and 2611 routers (The only connection is through console port and ethernet to the TFTP server).i have not connected the ISDN, ASDL or SERIAL INTERFACES with any cable. The routers recognize all the Ethernet and WAN interfaces. The ethernet LED is OK but the WAN cards LED are off. I have configured the interfaces of these WAN cards(A BRI, ISDN and SERIAL interfaces) with IP address, when i use the command Show interface i can see all the interfaces are UP and line protocol is UP. Is this enough to testify that the WAN interfaces are GOOD or is there any other technical way to test these interfaces. Does it need to connect all these WAN cards and PING them or is there a command which will be enough to prove that the WAN interfaces are all GOOD and not FAULTY. Can i use loopback command without using cables to test these interfaces? Please i need your help.
Best Regards
7 Replies 7
paolo bevilacqua
Hi, not diagnostic is 100% sure unless you connect the interface to something. That is the interface can be faulty passing all software diagnostic tests.
Depending on the interface, you connect differently for testing, eg serial using a null modem cable, ISDN BRI to a BRI port set as network-side, Ethernet and T1 ause a loopback plug, etc.
Thanks for your help
Can some one tell what is the diffrence between Data pattern [0xABCD]: 0x0000 (Data pattern [0xABCD]: 0x0000)
Router#ping ip
Target IP address: 172.22.53.1
0x1111
0xffff
0xaaaa
thanks in advance
ujil
These are just bit patterns to fill the payload with. Certain patterns are better "clock-breakers" than others, but the difference shows only on marginal circuits. That is, in practice you can ignore the pattern in everyday testing.
Hello ujil
I think oxABCD refers to hexadecimal and that
is 0x0000, 0x means the digits which follows such as
1111 or ffff or aaaa are hexadecimals digits.
each of these they translate a certain decimal value.
amouralamein
Thanks for your help.
