Bookmark
Subscribe
1640
TFTP Back Up error..
                   I am not able to take the TFTP back up of some of the devices.
I am getting the following error.. what is the reason  for the same. but i am able to reach my TFTP server IP.
% Error Opening tftp://X.X.X.X/yyy-confg (Timed Out).
what are basic thing i am need to check..
11 Replies 11
Rolf Fischer
Level 9
Level 9
Maybe the filename or the permission?
cant get you
Hello
Are these new tftp connections ( if so check any acl prohibiting connections)
How are you backing these up? =  from each device towards the tftp server or the other away around?
Are you using any utliity application like solarwinds/kiwi etc for the tftp server?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
i am using tftp server software, i  had taken the back up all devices.. Only switch i am not able to take the back up.
Router, Firewall and all other devices i had taken back up.. Only 2 switches which was connected in the T&D environment not able to take the back up.. I am suspecting  tftp may be blocking in firewall, But  then how i am  able to take the back up from firewall.
Hello
The swich may be probhiting tftp also!
Is this tftp server software using any snmp community strings?
Also try pushing the running -config from the swtiches itself
res
Paul
Thanks.
Kind Regards
Paul
how to check its prohibhiting..
Basically means that your appliance can't reach your TFTP server.
Could be a firewall issue or a routing issue.
check from that switch are u able to ping your pc that have tftp installed.
Jawad
Jawad
ya its reachable from switch.. i mentioned the same in question itself.. there is no specific in rule in firewall to block switches.. Other router and eventhough firewall also i am able to take the back up.
Switch i am able to reach the TFTP server Ip( i.e., system iP where TFTP server installed).
This error clearly indicated timed out. But i am able to reach server with minimum latency 30 ms?
any other  thing need to be checked in Switch.. checked with IP Socket as well..
Hongju Jung
Hello.
Can you share the full log message when you get the toward TFTP server ?
and did you make sure pingable from TFTP server to specific switch, if you can pingable to switch,
Consideration Server firewall disable
Kindly check same from other tftp server (installed into your pc and check), it can be tftp issue also
Jawad
Jawad
