the cpu reach 85 % when using cache server and return to 3% when shutdown it!!!
Dr.X
Level 2
Level 2
hi ,
recently i was uisng router 7206 as router gateway and the cache working fine and the max cpu was 50 %
now , i copied the config and pasted it in another router cisco 7600
every thing is fine , but i note the cpu is increasing and reached up to 85 %% !!!!!!!!!!!!!!
i just shutdown the cache server and the cpu became 3 % !!!!!!!!!!!!
which mean that the cache server is utilizng all of my cpu  .!!!!!!
actually , there are some config wasnt accepted  in 7600 which is under interface command
duplex full
speed auto
media-type rj45
negotiation auto
but i think that these lines has no affect in cache server cpu .
i will pase my config of cache with config of interfaces  ,  whch is currently in 7600
my question is how to start troubleshooting the cpu  utilization  because of cache ?
my issue  is when i was using 7206 the cpu biggest  value was 50 % when cache is full loaded . but in 7600 the utilization reached 85 % and still increasing !!
ip wccp 80 redirect-list CACHE80
ip wccp 90 redirect-list CACHE90
interface GigabitEthernet1/1
description zzz
bandwidth 230000
ip address 10.160.150.2 255.255.255.0
ip wccp 80 redirect in
ip policy route-map CACHE-REDIRECT
load-interval 30
interface GigabitEthernet1/2
description Cache
bandwidth 150000
ip address xxxxxxxx 255.255.255.248
ip wccp redirect exclude in
load-interval 30
interface GigabitEthernet1/3
description Internet from uuuuuuu
bandwidth 230000
ip address xxxxxxxxx 255.255.255.252
ip wccp 90 redirect in
load-interval 30
interface GigabitEthernet1/3.11
description Internet From rrrr
encapsulation dot1Q 11
ip address xxxxx
21 Replies 21
Dr.X
Level 2
Level 2
i think that  7600 router has a default config of startup config .
could this affect and make any issue ??
regards
Edison Ortiz
The 7600 has dedicated ASICs for WCCP thus the impact to the CPU is minimal.
The 7200 processes all packets on the CPU but you can alleviate this impact by using the following command under each of the interfaces where WCCP is enabled:
ip route-cache same-interface.
This will enable fast switching on packets which are switch out of the same interface they arrived.
http://www.cisco.com/en/US/docs/ios/ipswitch/command/reference/isw_i1.html#wp1085449
Edison
hi , Edison
im asking about 7600 and the problem is in 7600 not in 7206 ,
do you mean configuring the command
on router 7600 ???
regards
Sorry, I misread your question. I originally read you were moving from a 7600 to a 7200. My apologies.
Can you post your redirect-list (CACHE80 and CACHE90)?
There are some caveats when building redirect-list on hardware-assisted platforms such as the 7600.
No, you don't enter the 'ip route-cache same-interface' on the 7600 box.
Edison
hi ,
Edison
its okay
im versy sorry for hiding ips  for privacy.
here is config :
Gateway7600#sh ip access-lists CACHE80
Extended IP access list CACHE80
    10 deny tcp any hostzz.zz.4.69 eq www
    20 deny tcp host xx.xx.67.253 any eq www
    30 deny tcp any host zz.zz.92.59 eq www (316 matches)
    40 permit tcp xxxx.68.0 0.0.3.255 any eq www (115010480 matches)
    50 permit tcp xx.xx.72.0 0.0.3.255 any eq www (88556023 matches)
    60 permit tcp xx.xx.76.0 0.0.3.255 any eq www (59342978 matches)
    70 permit tcp xx.xx.67.0 0.0.0.255 any eq www (15182404 matches)
Gateway7600#sh ip access-lists CACHE90
Extended IP access list CACHE90
    10 permit tcp any xx.xx.67.0 0.0.0.255 (417403 matches)
    20 permit tcp any xx.xx.68.0 0.0.3.255 (3551977 matches)
    30 permit tcp any xx.xx.72.0 0.0.3.255 (2701614 matches)
    40 permit tcp any xx.xx.76.0 0.0.3.255 (1671664 matches)
Your ACL looks fine.
Please post the output from the following commands:
show ip cef switching stat
show ip cef switch stat fea
show process cpu | exclude 0.00
show ip wccp
show ip wccp interface detail
show ip wccp web-cache service
show ip wccp web-cache detail
show tcam counts
show mls netflow table-contention aggregate
show mls netflow table-contention detail
show mls netflow ip counts
show mls netflow ip sw-installed
show mls statistics
sorry again for hiding ips ,note that xxx is the same as xx in the redirect-list
please  dont put me down , i  want to install 7600 with cahe and wish doing  that without problems
Gateway7600#show ip cef switching stat
       Reason                          Drop       Punt  Punt2Host
RP LES No route                           0          0         12
RP LES Packet destined for us             0      79518          0
RP LES Incomplete adjacency          122556          0          0
RP LES TTL expired                        0          0       1045
RP LES IP redirects                       0          0         46
RP LES Neighbor resolution req           69          7          0
RP LES Total                         122625      79525       1103
All    Total                         122625      79525       1103
Gateway7600#show ip cef switch stat fea
IPv4 CEF input features:
       Feature                Drop    Consume       Punt  Punt2Host Gave route
       Policy Routing            0          0          0          0  284112859
Total                            0          0          0          0  284112859
IPv4 CEF output features:
       Feature                Drop    Consume       Punt  Punt2Host    New i/f
Total                            0          0          0          0          0
IPv4 CEF post-encap features:
Total                            0          0          0          0          0
IPv4 CEF for us features:
Total                            0          0          0          0          0
IPv4 CEF punt features:
Total                            0          0          0          0          0
IPv4 CEF local features:
Total                            0          0          0          0          0
Gateway7600#show process cpu | exclude 0.00
CPU utilization for five seconds: 69%/69%; one minute: 75%; five minutes: 58%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   2       41592       36229       1148  0.08%  0.05%  0.05%   0 Load Meter
  13       92628      390753        237  0.08%  0.16%  0.15%   0 ARP Input
232      184824      380647        485  0.08%  0.22%  0.23%   0 IP Input
270       19756    22897940          0  0.08%  0.03%  0.04%   0 Ethernet Msec Ti
339       11100       59525        186  0.16%  0.10%  0.11%   5 Virtual Exec
541      113176      427936        264  0.08%  0.02%  0.01%   0 Port manager pe
Gateway7600#show ip wccp
Global WCCP information:
    Router information:
        Router Identifier:                   hh.hh.66.78
        Protocol Version:                    2.0
    Service Identifier: 80
        Number of Service Group Clients:     1
        Number of Service Group Routers:     1
        Total Packets Redirected:            2055832
          Process:                           0
          CEF:                               2055832
        Service mode:                        Open
        Service Access-list:                 -none-
        Total Packets Dropped Closed:        0
        Redirect access-list:                CACHE80
        Total Packets Denied Redirect:       615
        Total Packets Unassigned:            199019
        Group access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total GRE Bypassed Packets Received: 0
          Process:                           0
          CEF:                               0
    Service Identifier: 90
        Total Packets Redirected:            99681
          Process:                           0
          CEF:                               99681
        Service mode:                        Open
        Redirect access-list:                CACHE90
        Total Packets Denied Redirect:       1
        Total Packets Unassigned:            254204
          Process:                           0
          CEF:                               0
Gateway7600#
Gateway7600#
Gateway7600#show ip wccp interface detail
WCCP interface configuration details:
    GigabitEthernet1/1
        Output services: 0
        Input services:  1
            Dynamic:     80
        Mcast services:  0
        Exclude In:      FALSE
    GigabitEthernet1/2
        Output services: 0
        Input services:  0
        Mcast services:  0
        Exclude In:      TRUE
    GigabitEthernet1/3
        Output services: 0
        Input services:  1
            Dynamic:     90
        Mcast services:  0
        Exclude In:      FALSE
        Output services: 0
        Input services:  1
            Dynamic:     90
        Mcast services:  0
        Exclude In:      FALSE
Gateway7600#
Gateway7600#
Gateway7600#show ip wccp web-cache service
The WCCP service specified does not exist.
Gateway7600#show ip wccp web-cache detail
Gateway7600#show tcam counts
           Used        Free        Percent Used       Reserved
Labels:(in)  6        4090            0
Labels:(eg)  2        4094            0
ACL_TCAM
  Masks:     43        4053            1                    72
Entries:    102       32666            0                   576
QOS_TCAM
  Masks:      4        4092            0                    18
Entries:     22       32746            0                   144
    LOU:      0         128            0
  ANDOR:      0          16            0
  ORAND:      0          16            0
    ADJ:      5        2043            0
Gateway7600#show mls netflow table-contention aggregate
Earl in Module 1
Aggregate Netflow CAM Contention Information
Netflow Creation Failures    :   10604563
Netflow Hash Aliases         :   0
Gateway7600#show mls netflow table-contention detail
Earl in Module 1
Detailed Netflow CAM (TCAM and ICAM) Utilization
TCAM Utilization             :   100%
ICAM Utilization             :   4%
Netflow TCAM count           :   130950
Netflow ICAM count           :   6
Netflow Creation Failures    :   49585
Netflow CAM aliases          :   0
Gateway7600#show mls netflow ip counts
% Invalid input detected at '^' marker.
Displaying Netflow entries in Supervisor Earl
Number of shortcuts = 130948
Gateway7600#show mls netflow ip sw-installed
DstIP           SrcIP           Prot:SrcPort:DstPort  Src i/f          :AdjPtr
Pkts         Bytes         Age   LastSeen  Attributes
xx.xx.68.205   zzz.zzz.66.24   tcp :www    :50874    Gi1/3.11         :0x80002
11           15862         236   13:49:13   L3 - SwInstalled
xx.xx.77.76    zzz.zzz.66.23   tcp :www    :50687    Gi1/3.11         :0x80002
11           15972         236   13:49:14   L3 - SwInstalled
xx.xx.69.187   zzz.zzz.66.23   tcp :www    :50922    Gi1/3.11         :0x80002
13           18876         236   13:49:11   L3 - SwInstalled
xx.xx.70.95    207.241.236.224 tcp :www    :51811    Gi1/3.11         :0x80002
3            4356          236   13:48:25   L3 - SwInstalled
xx.xx.72.24    173.194.67.104  tcp :www    :12777    Gi1/3.11         :0x80002
10           14400         236   13:49:14   L3 - SwInstalled
xx.xx.73.34    173.194.5.38    tcp :www    :20333    Gi1/3.11         :0x80002
4            5760          236   13:49:35   L3 - SwInstalled
xx.xx.74.20    178.79.198.147  tcp :www    :65270    Gi1/3.11         :0x80002
9            10256         236   13:50:23   L3 - SwInstalled
xx.xx.74.201   zzz.zzz.66.24   tcp :www    :18370    Gi1/3.11         :0x80002
12           17280         236   13:49:12   L3 - SwInstalled
xx.xx.76.86    79.140.80.17    tcp :www    :57835    Gi1/3.11         :0x80002
6            8712          236   13:50:49   L3 - SwInstalled
xx.xx.73.61    zzz.zzz.66.17   tcp :www    :11351    Gi1/3.11         :0x80002
11           15840         236   13:49:14   L3 - SwInstalled
xx.xx.74.198   zzz.zzz.66.19   tcp :www    :61514    Gi1/3.11         :0x80002
11           15972         236   13:49:02   L3 - SwInstalled
xx.xx.76.9     87.98.209.3     tcp :www    :11001    Gi1/3.11         :0x80002
5            7200          236   13:49:27   L3 - SwInstalled
xx.xx.77.79    66.220.152.32   tcp :www    :12945    Gi1/3.11         :0x80002
2            2880          236   13:48:28   L3 - SwInstalled
xx.xx.70.131   173.194.5.141   tcp :www    :10370    Gi1/3.11         :0x80002
5            7200          236   13:49:24   L3 - SwInstalled
xx.xx.78.3     zzz.zzz.66.20   tcp :www    :10270    Gi1/3.11         :0x80002
11           15840         236   13:49:06   L3 - SwInstalled
xx.xx.70.136   zzz.zzz.66.22   tcp :www    :3911     Gi1/3.11         :0x80002
12           16800         236   13:49:13   L3 - SwInstalled
xx.xx.72.67    zzz.zzz.66.23   tcp :www    :21061    Gi1/3.11         :0x80002
13           18720         236   13:49:11   L3 - SwInstalled
xx.xx.73.185   zzz.zzz.66.22   tcp :www    :16748    Gi1/3.11         :0x80002
14           20160         236   13:49:14   L3 - SwInstalled
xx.xx.69.192   173.194.5.8     tcp :www    :16808    Gi1/3.11         :0x80002
3            4320          236   13:50:06   L3 - SwInstalled
xx.xx.78.25    zzz.zzz.66.23   tcp :www    :49356    Gi1/3.11         :0x80002
11           15972         236   13:49:12   L3 - SwInstalled
xx.xx.74.205   zzz.zzz.66.17   tcp :www    :11693    Gi1/3.11         :0x80002
13           18720         236   13:49:15   L3 - SwInstalled
xx.xx.75.212   69.171.224.53   tcp :www    :14515    Gi1/3.11         :0x80002
6            8640          236   13:49:13   L3 - SwInstalled
xx.xx.67.26    199.91.153.58   tcp :www    :16488    Gi1/3.11         :0x80002
2            2904          236   13:49:18   L3 - SwInstalled
xx.xx.72.237   198.78.208.254  tcp :www    :53604    Gi1/3.11         :0x80002
5            7260          236   13:49:31   L3 - SwInstalled
xx.xx.75.9     zzz.zzz.66.19   tcp :www    :49459    Gi1/3.11         :0x80002
12           17424         236   13:49:13   L3 - SwInstalled
xx.xx.74.79    zzz.zzz.66.18   tcp :www    :12560    Gi1/3.11         :0x80002
13           18720         236   13:49:10   L3 - SwInstalled
xx.xx.72.155   178.79.198.135  tcp :www    :21817    Gi1/3.11         :0x80002
11           13052         236   13:50:04   L3 - SwInstalled
xx.xx.72.185   212.150.101.6   tcp :www    :11604    Gi1/3.11         :0x80002
25           36000         236   13:48:58   L3 - SwInstalled
xx.xx.78.49    zzz.zzz.66.21   tcp :www    :56324    Gi1/3.11         :0x80002
10           14520         236   13:49:10   L3 - SwInstalled
xx.xx.70.175   178.79.198.146  tcp :www    :11769    Gi1/3.11         :0x80002
9            10172         236   13:50:19   L3 - SwInstalled
xx.xx.74.70    173.194.5.145   tcp :www    :3593     Gi1/3.11         :0x80002
5            7260          236   13:50:53   L3 - SwInstalled
xx.xx.73.253   zzz.zzz.66.17   tcp :www    :10482    Gi1/3.11         :0x80002
11           15840         236   13:49:12   L3 - SwInstalled
xx.xx.70.55    78.140.176.225  tcp :www    :3224     Gi1/3.11         :0x80002
5            7260          236   13:48:20   L3 - SwInstalled
xx.xx.70.246   95.211.138.16   tcp :www    :14537    Gi1/3.11         :0x80002
6            8640          236   13:49:15   L3 - SwInstalled
xx.xx.70.78    zzz.zzz.66.21   tcp :www    :24618    Gi1/3.11         :0x80002
9            12960         236   13:49:04   L3 - SwInstalled
xx.xx.76.99    15.192.45.138   tcp :www    :15200    Gi1/3.11         :0x80002
7            9940          236   13:50:28   L3 - SwInstalled
xx.xx.74.29    69.171.224.53   tcp :www    :49438    Gi1/3.11         :0x80002
2            2904          236   13:48:31   L3 - SwInstalled
xx.xx.70.47    zzz.zzz.66.24   tcp :www    :12475    Gi1/3.11         :0x80002
12           17280         236   13:49:00   L3 - SwInstalled
xx.xx.68.190   zzz.zzz.83.194  tcp :www    :50422    Gi1/3.11         :0x80002
3            4356          236   13:47:42   L3 - SwInstalled
xx.xx.74.158   69.171.224.37   tcp :www    :10547    Gi1/3.11         :0x80002
3            4356          236   13:48:33   L3 - SwInstalled
xx.xx.72.125   199.91.154.147  tcp :www    :22782    Gi1/3.11         :0x80002
5            7200          236   13:48:57   L3 - SwInstalled
xx.xx.76.102   23.62.236.17    tcp :www    :10273    Gi1/3.11         :0x80002
7            10080         236   13:50:10   L3 - SwInstalled
xx.xx.67.150   95.211.105.156  tcp :www    :58103    Gi1/3.11         :0x80002
6            8712          236   13:49:42   L3 - SwInstalled
xx.xx.73.6     173.194.5.244   tcp :www    :28819    Gi1/3.11         :0x80002
5            7260          236   13:49:39   L3 - SwInstalled
xx.xx.74.201   zzz.zzz.66.24   tcp :www    :18368    Gi1/3.11         :0x80002
9            12960         236   13:49:13   L3 - SwInstalled
xx.xx.75.163   184.172.142.179 tcp :www    :14320    Gi1/3.11         :0x80002
6            8640          236   13:49:05   L3 - SwInstalled
xx.xx.74.167   zzz.zzz.66.18   tcp :www    :13520    Gi1/3.11         :0x80002
13           18720         236   13:49:13   L3 - SwInstalled
xx.xx.78.3     zzz.zzz.66.20   tcp :www    :11011    Gi1/3.11         :0x80002
xx.xx.71.153   zzz.zzz.66.23   tcp :www    :11198    Gi1/3.11         :0x80002
8            11520         236   13:48:45   L3 - SwInstalled
xx.xx.75.240   85.17.127.65    tcp :www    :1983     Gi1/3.11         :0x80002
3            4356          236   13:49:18   L3 - SwInstalled
xx.xx.70.117   173.194.78.154  tcp :www    :42359    Gi1/3.11         :0x80002
4            2728          134   13:50:11   L3 - SwInstalled
xx.xx.67.159   208.111.185.156 tcp :www    :20828    Gi1/3.11         :0x80002
8            8732          236   13:50:06   L3 - SwInstalled
xx.xx.68.205   zzz.zzz.66.24   tcp :www    :50878    Gi1/3.11         :0x80002
13           18746         236   13:49:14   L3 - SwInstalled
xx.xx.71.216   zzz.zzz.66.19   tcp :www    :10393    Gi1/3.11         :0x80002
8            11520         236   13:49:02   L3 - SwInstalled
xx.xx.77.37    173.194.78.99   tcp :www    :18942    Gi1/3.11         :0x80002
3            3266          102   13:49:23   L3 - SwInstalled
xx.xx.71.153   zzz.zzz.66.23   tcp :www    :11294    Gi1/3.11         :0x80002
10           14400         236   13:49:05   L3 - SwInstalled
xx.xx.75.229   zzz.zzz.66.17   tcp :www    :12422    Gi1/3.11         :0x80002
12           17280         236   13:49:10   L3 - SwInstalled
xx.xx.69.237   178.79.198.154  tcp :www    :13615    Gi1/3.11         :0x80002
9            8778          236   13:51:03   L3 - SwInstalled
xx.xx.68.94    zzz.zzz.66.23   tcp :www    :17127    Gi1/3.11         :0x80002
11           15840         236   13:49:11   L3 - SwInstalled
xx.xx.77.247   zzz.zzz.66.16   tcp :www    :13084    Gi1/3.11         :0x80002
13           18720         236   13:49:14   L3 - SwInstalled
xx.xx.70.95    207.241.236.224 tcp :www    :51838    Gi1/3.11         :0x80002
3            4356          236   13:48:05   L3 - SwInstalled
xx.xx.72.5     69.171.237.16   tcp :www    :16458    Gi1/3.11         :0x80002
0            0             236   13:48:00   L3 - SwInstalled
xx.xx.71.19    79.140.95.115   tcp :www    :13119    Gi1/3.11         :0x80002
3            4320          236   13:50:10   L3 - SwInstalled
xx.xx.69.176   79.140.80.72    tcp :www    :2493     Gi1/3.11         :0x80002
7            10164         236   13:50:05   L3 - SwInstalled
xx.xx.69.192   173.194.5.8     tcp :www    :16703    Gi1/3.11         :0x80002
5            7200          236   13:49:26   L3 - SwInstalled
xx.xx.67.214   79.140.95.144   tcp :www    :52625    Gi1/3.11         :0x80002
14           20328         236   13:50:53   L3 - SwInstalled
xx.xx.71.30    93.184.220.124  tcp :www    :2022     Gi1/3.11         :0x80002
4            5808          236   13:50:32   L3 - SwInstalled
xx.xx.77.252   zzz.zzz.66.16   tcp :www    :18070    Gi1/3.11         :0x80002
11           15840         236   13:49:07   L3 - SwInstalled
xx.xx.75.169   zzz.zzz.66.20   tcp :www    :10100    Gi1/3.11         :0x80002
12           17280         236   13:49:14   L3 - SwInstalled
xx.xx.67.169   38.104.58.182   tcp :www    :26813    Gi1/3.11         :0x80002
13           18720         236   13:48:42   L3 - SwInstalled
xx.xx.71.239   178.236.7.33    tcp :www    :13601    Gi1/3.11         :0x80002
5            5646          236   13:50:59   L3 - SwInstalled
xx.xx.73.85    80.239.152.11   tcp :www    :59291    Gi1/3.11         :0x80002
3            4356          236   13:47:51   L3 - SwInstalled
xx.xx.76.214   173.194.5.116   tcp :www    :18703    Gi1/3.11         :0x80002
6            8640          236   13:49:26   L3 - SwInstalled
xx.xx.77.39    69.171.234.41   tcp :www    :16837    Gi1/3.11         :0x80002
6            1572          236   13:49:16   L3 - SwInstalled
xx.xx.77.213   zzz.zzz.66.17   tcp :www    :4002     Gi1/3.11         :0x80002
14           20328         236   13:49:13   L3 - SwInstalled
xx.xx.73.145   95.211.105.156  tcp :www    :4206     Gi1/3.11         :0x80002
8            11616         236   13:50:41   L3 - SwInstalled
xx.xx.69.176   79.140.80.72    tcp :www    :2492     Gi1/3.11         :0x80002
7            10164         236   13:50:40   L3 - SwInstalled
xx.xx.77.186   69.171.229.74   tcp :www    :2174     Gi1/3.11         :0x80002
12           17424         236   13:48:33   L3 - SwInstalled
xx.xx.77.252   zzz.zzz.66.16   tcp :www    :17921    Gi1/3.11         :0x80002
11           15840         236   13:49:17   L3 - SwInstalled
xx.xx.69.90    zzz.zzz.66.16   tcp :www    :2706     Gi1/3.11         :0x80002
10           14520         236   13:49:13   L3 - SwInstalled
xx.xx.77.207   213.131.66.55   tcp :www    :12006    Gi1/3.11         :0x80002
4            5760          236   13:48:06   L3 - SwInstalled
xx.xx.77.24    zzz.zzz.66.21   tcp :www    :11064    Gi1/3.11         :0x80002
13           18720         236   13:49:12   L3 - SwInstalled
xx.xx.72.238   69.171.237.32   tcp :www    :55696    Gi1/3.11         :0x80002
2            2904          236   13:49:03   L3 - SwInstalled
xx.xx.73.162   zzz.zzz.66.18   tcp :www    :13174    Gi1/3.11         :0x80002
xx.xx.76.47    87.240.161.76   tcp :www    :52801    Gi1/3.11         :0x80002
4            5808          236   13:48:17   L3 - SwInstalled
xx.xx.71.216   zzz.zzz.66.19   tcp :www    :10353    Gi1/3.11         :0x80002
11           15840         236   13:49:15   L3 - SwInstalled
xx.xx.68.128   zzz.zzz.66.22   tcp :www    :10645    Gi1/3.11         :0x80002
12           17280         236   13:49:15   L3 - SwInstalled
xx.xx.70.50    zzz.zzz.66.17   tcp :www    :26288    Gi1/3.11         :0x80002
xx.xx.72.13    85.17.124.121   tcp :www    :11761    Gi1/3.11         :0x80002
7            10080         236   13:49:20   L3 - SwInstalled
xx.xx.73.145   85.17.78.129    tcp :www    :4196     Gi1/3.11         :0x80002
5            7260          236   13:50:07   L3 - SwInstalled
xx.xx.71.216   zzz.zzz.66.19   tcp :www    :10359    Gi1/3.11         :0x80002
xx.xx.67.227   216.59.3.148    tcp :www    :50187    Gi1/3.11         :0x80002
5            7260          236   13:49:28   L3 - SwInstalled
xx.xx.69.198   zzz.zzz.66.22   tcp :www    :18279    Gi1/3.11         :0x80002
xx.xx.77.76    zzz.zzz.66.23   tcp :www    :50652    Gi1/3.11         :0x80002
12           17424         236   13:49:09   L3 - SwInstalled
xx.xx.75.180   zzz.zzz.66.16   tcp :www    :24071    Gi1/3.11         :0x80002
11           15840         236   13:49:13   L3 - SwInstalled
xx.xx.78.82    zzz.zzz.66.21   tcp :www    :10424    Gi1/3.11         :0x80002
14           20160         236   13:49:13   L3 - SwInstalled
xx.xx.68.110   95.211.105.155  tcp :www    :50789    Gi1/3.11         :0x80002
6            8712          236   13:49:57   L3 - SwInstalled
xx.xx.74.20    178.79.198.148  tcp :www    :65271    Gi1/3.11         :0x80002
9            10256         236   13:50:40   L3 - SwInstalled
xx.xx.69.176   79.140.80.72    tcp :www    :2494     Gi1/3.11         :0x80002
6            8712          236   13:50:26   L3 - SwInstalled
xx.xx.77.218   zzz.zzz.66.21   tcp :www    :1352     Gi1/3.11         :0x80002
11           15972         236   13:49:15   L3 - SwInstalled
xx.xx.76.105   85.17.25.11     tcp :www    :49779    Gi1/3.11         :0x80002
4            5808          236   13:51:03   L3 - SwInstalled
xx.xx.72.84    zzz.zzz.66.17   tcp :www    :15418    Gi1/3.11         :0x80002
11           15840         236   13:49:08   L3 - SwInstalled
xx.xx.74.136   208.117.240.77  tcp :www    :15932    Gi1/3.11         :0x80002
6            8640          236   13:49:38   L3 - SwInstalled
xx.xx.69.2     208.43.71.145   tcp :www    :50422    Gi1/3.11         :0x80002
6            8712          236   13:48:55   L3 - SwInstalled
xx.xx.71.154   zzz.zzz.66.19   tcp :www    :15128    Gi1/3.11         :0x80002
12           17280         236   13:49:11   L3 - SwInstalled
xx.xx.69.3     zzz.zzz.66.24   tcp :www    :13571    Gi1/3.11         :0x80002
Gateway7600#
Gateway7600#show mls statistics
Statistics for Earl in Module 1
L2 Forwarding Engine
  Total packets Switched                : 2613104173
L3 Forwarding Engine
  Total packets Processed               : 2612898195 @ 113279 pps
  Total packets L3 Switched             : 1961063719 @ 73721 pps
  Total Packets Bridged                 : 585946922
  Total Packets FIB Switched            : 1223374926
  Total Packets ACL Routed              : 491568212
  Total Packets Netflow Switched        : 246120581
  Total Mcast Packets Switched/Routed   : 436835
  Total ip packets with TOS changed     : 2
  Total ip packets with COS changed     : 2
  Total non ip packets COS changed      : 0
  Total packets dropped by ACL          : 241
  Total packets dropped by Policing     : 0
  Total packets exceeding CIR           : 0
  Total packets exceeding PIR           : 0
Errors
  MAC/IP length inconsistencies         : 0
  Short IP packets received             : 0
  IP header checksum errors             : 0
  No-route packet drops                 : 12
  TTL failures                          : 270124
  MTU failures                          : 0
Total packets L3 Processed by all Modules: 2612898195 @ 113279 pps
On
description zzz
bandwidth 230000
load-interval 30
can you remove the policy route-map and see if the CPU drops?
I noticed from the output, lots of packets punted to the CPU from the PBR.
What's the reason for this PBR?
Can you add the pertinent configuration for this PBR? route-map and ACL?
Based on the show proc cpu, your issue is interrupt traffic.
Edison
hi , mr Edison ,
the ip ploicy is just becuse i have two internet sources , and this direct my useres to the internet .
you are right ,  im noting that the internet traffic is not natural and thgouht that there is a drop  , here is a screenshot of internet graph after shutting down  cache server .
http://www7.0zz0.com/2012/07/30/15/691686492.png
as you see, the traffic is getting breaking down and up .  but this breaking wasnt  when i was using 7206
any way , do you think that ip policy may be the reason of the interrupting and cache problems?? if yes , how to start troubleshoot it ??
here is the config
Gateway7600#sh route-map CACHE-REDIRECT
route-map CACHE-REDIRECT, permit, sequence 5
  Match clauses:
    ip address (access-lists): TO_DMZ
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
route-map CACHE-REDIRECT, permit, sequence 10
  Match clauses:
    ip address (access-lists): 100
  Set clauses:
    ip next-hop ttt.ttt.66.77
route-map CACHE-REDIRECT, permit, sequence 20
  Match clauses:
    ip address (access-lists): isp1
  Set clauses:
    ip next-hop vv.vv.56.165
  Policy routing matches: 21040 packets, 1647130 bytes
route-map CACHE-REDIRECT, permit, sequence 30
  Match clauses:
    ip address (access-lists): isp2
  Set clauses:
    ip next-hop bbb.bbb.66.77
  Policy routing matches: 285732280 packets, 31199066079 bytes
route-map CACHE-REDIRECT, permit, sequence 100
  Match clauses:
  Set clauses:
  Policy routing matches: 389354 packets, 45835914 bytes
im also noting that alot of matching in  this ip policy.
regards
Let's start by removing PBR from G1/1 and observe if the CPU drops.
I understand you need the PBR to distribute your user traffic but you may be having conflicting features enabled on the same interface.
Can you post the ACLs referred within the route-map?
Are you redirecting with WCCP and PBR the same src/dst ?
Engineering your network with hardware assisted platforms is quite different than with a regular IOS router.
ok , i will  test it later and give u a reply
i cant stop it now
thanks very much
regards
Looking at your output one more time, PBR isn't punting the traffic.
The output provided in the forum didn't line up correctly and I thought Punt2Host numbers were
284112859 but in reality is assigned to the GaveRoute column. Can you confirm this for me?
What version of IOS are you running on this box? Please provide the 'show ver' output.
Also, is the Cache Engine directly connected to this box?
hi , hereis the sh again , but remember , i did itwhile the cache is not working .
again , i will try to remove pbr and give u a reply when i have the chance to do it .
and here is the output
       Policy Routing            0          0          0          0  285533522
Total                            0          0          0          0  285533522
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Total                            0          0          0          0          0
Gateway7600#
here is sh ver
Gateway7600#
Gateway7600#sh ve
Gateway7600#sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sun 27-Nov-11 15:27 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVENTERPRISEK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)
Gateway7600 uptime is 2 days, 4 hours, 11 minutes
Uptime for this control processor is 2 days, 4 hours, 11 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7604 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID FOX1509G2DK
R7000 CPU at 300MHz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
1 Virtual Ethernet interface
9 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Gateway7600#
Gateway7600#
about the cache connection .
the cache server is connected to switch and the router is conneted to the same switch .
regards
hi , i just want to mention that this policy was okay when i was using 7206 , do you think  a conflic may occur in 7600 ??
im sorry,  i didnt understand  this question .
here is the config of ACL
Extended IP access list isp1
    10 permit ip xx.xx.64.0 0.0.1.255 any (41830 matches)
Extended IP access list isp2
    10 permit ip xx.xx.66.0 0.0.1.255 any (15673605 matches)
    20 permit ip xx.xx.68.0 0.0.3.255 any (117877748 matches)
    30 permit ip xx.xx.72.0 0.0.3.255 any (91318175 matches)
    40 permit ip xx.xx.76.0 0.0.3.255 any (61154622 matches)
regards
