The difference between different 8200 router images
Herman2018
Level 3
Level 3
Hi, we plan to purchase catalyst 8200 routers, but from CCW, there are multiple image options, like universal
xxxk9.176, xxxk9.1176
Can someone please advise what the differences between these images? How to select ? thanks in advance!
DanielP211
Hello Herman!
The option only depends on which image comes preloaded. You will be able to change the image later on. It is usually best to go with the golden image to save you the hassle. I would go with
SC8KBEUK9-176
currently which is the golden one.
BR
****Kindly rate all useful posts*****
DanielP211
Hello Herman!
SC8KBEUK9-176
BR
Thanks @DanielP211 . Can you please advise where can find the difference among these images?
ju_mobile
Hi Herman,
The difference is simply the image version of code, for example <value>-1712 = 17.12 and <value>-173 = 17.3 and as detailed here : Cisco Catalyst 8300/8200 Series Edge Platforms Ordering Guide - Cisco
If you wish to view the variations between the code versions, then the best place to look is on the 'Downloads' and review the associated release notes. I would recommend paying particular attention to the 'new features', and 'resolved bugs'.
Kind Regards
Ju
