the ISR4400 router supports AC and DC simultaneously?
Rafael Sousa
Hello, could you confirm that the ISR4400 router supports AC and DC simultaneously?
10ks
Joseph W. Doherty
Don't know, but such a feature isn't as common as it once was.
If you find the ISR doesn't have that as a feature, you might consider using dual AC with one side fed from a DC to AC inverter.
balaji.bandi
Personally NO - that is not a suggest method.
BB
Joseph W. Doherty
