there is log channel-misconfig
sakolvaree
Hi Expert
I facing log file form cisco switch like this
PM-4-ERR_DISABLE: channel-misconfig error detected on GiX/X, putting GiX/X in err-disable state
I've verify all config are match correctly. if I want to bypass checking
what difference between command
1. "no spanning-tree etherchannel guard misconfig"
2. "no error-disable detect cause channel-misconfig"
and how effect between 2 cli
from my research https://supportforums.cisco.com/thread/2173351 1. is feature of STP for detect misconfig
Amit Singh
The first command will disable the ether-channel guard misconfig on the switch.Yes, its used by STP for any misconfiguration, ideally the settings and port capabilities have to be identical on both the ports/sides.
The second command will disable the interface shutdown from channel-misconfig errors.
One will detect it and the other will put the ports in shutdown state so these two command go hand-in-hand.
-amit singh
thankyou very much
please share document that explain this
This line is very specific.  It means that the port-channel configurations to some of your physical interface is inconsistent and the Cisco appliance, which can't read your mind to determine which one of the configuration you want, disables the port(s) until you fix the issue.
Using either one of these two will not be of any help.  You've got an inconsistent configuration.  Fix that.  Post the interface configuration of all the physical interface as well as the logical (port-channel) interface so we will be able to help you determine where the problem lies.
sakolvaree
Hi All
I've verify all configuration and physical are correct log occur since 1 week ago  there are no configuration change in port-channel in each device
Topology like hub and spoke Hub device is Other vender spoke device are Cisco
log occur 1-2 time per day when auto-recovery work and port comup everything work fine
now I use  "no spanning-tree etherchannel guard misconfig"
