Third-party Compact Flash - 1841 Router
myounger
I have a Cisco 1841 router. Can I use standard (ex. Purchased at Best Buy or Walmart) compact flash memory when upgrading. I know in the past this would not work, especially with the Catalyst 6500 series.
Leo Laohoo
Hi Matt,
Not all 3rd party CF will work so you'll have to do some trial-and-error.
bretjaquish
Level 3
Level 3
I bought a 1GB CF Type 2 card for an ISR router in my lab environment and it worked great. Just remember to format it to the model of router you have.
I actually have a media reader in which I copy all of the files over within windows (beats TFTP) and then load the card and boot.
Leo Laohoo
Before I forget, maximum CF or USB size is 2Gb.
