Throughput over DMVPN ipsce tunnel
nec82
Hello colleagues!  It might be a silly question but I've encountered with  strange behavior. I tested throughput with iperf  over an DMVPN ipsec tunnel and got some counterpart results. For instance, one session tcp test generates throughput no more 11 mbit/s, the 10 session tcp  about 70-80 mbit/s. The same test with UDP might generate 50-70 mbit/s flow but with some packet loss (about 6-10 percent). Here is the scheme
Server - ISR4221 (GREoverIPSEC(MTU 1400) over PPPOE Dialer with MTU 1492) - Internet -(GREoverIPSEC(MTU 1400) over Eth) ISR4331 - Server .
All tunnels have ADJ TCP MSS 1360 and MTU 1400. Ping  with overall size 1400 and df-bit between servers works fine.
While testing I haven't  seen any errors on both side like CERM LIMITS or overload of PPEs. In addition, I tried packet-tracer on ISR 4221 and didn't see any packet drops. Here is statistics
show platform packet-trace statistics
Packets Summary
Matched 80661
Traced 50400
Packets Received
Ingress 30261
Inject 0
Packets Processed
Forward 55461
Punt 0
Drop 0
Consume 0
show platform hardware qfp active datapath utilization
CPP 0: Subdev 0 5 secs 1 min 5 min 60 min
Input: Priority (pps) 0 0 0 0
(bps) 0 0 0 0
Non-Priority (pps) 5359 5131 4314 4098
(bps) 33659800 32960664 22664464 18163528
Total (pps) 5359 5131 4314 4098
Output: Priority (pps) 0 0 0 0
(bps) 0 0 0 0
Non-Priority (pps) 5292 5071 4256 4076
(bps) 32410936 31830096 22183672 18079072
Total (pps) 5292 5071 4256 4076
Processing: Load (pct) 20 17 14 13
So the question is why one session tcp flow has so low throughput ? Is there a way how to overcome such an issue?
11 Replies 11
are you using the values below on your tunnel interfaces ? And if not, can you configure these and test again ?
interface Tunnel0
ip mtu 1400
ip tcp adjust-mss 1360
I'm using exactly the same values
my apologies, I saw that you already mentioned that you are using these values in your original post...
Either way, what you are experiencing might just be related to the way TCP and UDP work. I have found the article below that explains it quite well I think:
--> TCP is a connection-oriented protocol, whereas UDP is a connectionless protocol. A key difference between TCP and UDP is speed, as TCP is comparatively slower than UDP. Overall, UDP is a much faster, simpler, and efficient protocol, however, retransmission of lost data packets is only possible with TCP.
https://www.lifesize.com/en/blog/tcp-vs-udp/#:~:text=TCP%20is%20a%20connection%2Doriented,is%20only%20possible%20with%20TCP.
BTW, I would take some of the information provided in the Lifesize Blog, with a very large grain of salt.
TCP vs. UDP, in actual usage, and their impact on networks, is, just a bit, more complex than what the article describes.
Without going into a full desertion on TCP vs. UDP, but if you believe the forgoing article's "But because UDP avoids the unnecessary overheads of TCP transport, it’s incredibly efficient in terms of bandwidth, and much less demanding of poor performing networks, as well." I would recommend anyone start with https://en.wikipedia.org/wiki/Network_congestion#Congestive_collapse.  You might also look deeper into, applications that use UDP, because although they don't really need all of TCP features, often "re-implement" some key features of TCP.  UDP usage can easily lead to "poor performing networks" and w/o using some key TCP features can easily lead to congestion collapse.
Basically, "buyer beware" when reading any vendor's literature touting the benefits of their application when they use UDP and/or their "better than TCP" proprietary protocol.  (NB: BTW, not saying all UDP applications are bad, but TCP's features also include avoiding network collapse.  Also, TCP isn't quite as bad as it is often purported to be, often one only needs to better understand it [see research subjects, mentioned in my prior posting].)
Giuseppe Larosa
Hello @nec82 ,
a TCP sender has to wait for an ACK from the receiver and the TCP window size plays a role here. Better results can be achieved if the two TCP endpoints implement the extended TCP window.
I would say your results are reasonable with standard TCP windows size.
Hope to help
Giuseppe
Thanks for explantion. Today I tried the same tests  with no encryption on routers (just gre). Here are results:
One session tcp generates about 17mbit/s in comparison with the same test with encryption which gives  me 7-10mbit/s
I checked PPE utilization  on both routers while doing testing with encryption. The result is no huge utilization (about 30 percent) and no CERM LIMIT messages. Look like it is not the routers performance but why throughput might differ by two times?
router#show platform cerm-information | include pkt
can you share output of this ?
Joseph W. Doherty
Insufficient information to really say what's the cause of your issues, but in general, what @Giuseppe Larosa mentions about TCP window sizes, and ACKs, are very important when it comes to TCP transfer rate (a few other variable come into play, too).  (More on this subject might be found by searching the Internet for BDP [bandwidth delay product] and also LFN [long fat networks], the latter, though, possibly not quite as impactful in your case.)
There are other variables, too, that would impact your transfer rate.  For example, interesting is your UDP loss rate.  (TCP is much slowed by packet loss, especially if it trigger time outs.)  Also interesting is your PPPoE (with its reduced MTU).
With your UDP transfer rate stats, I wondering whether you might need a shaper.  It's seems counter intuitive, but by slowing your transmission rate from your router, effect transfer rate might increase.
Regarding lack of information, to start with, what's the physical interface bandwidths at your two sites. Do either of your site's physical Internet connections have a ISP bandwidth cap, in and/or out?  What's the usual latency between your two routers?
nec82
Hello folks! The solution is to change ISP :). I don't know why but the old ISP somehow reduces throughput  of IPSEC traffic
Yea, changing ISP (and/or SP) can sometime do wonders.  (Laugh - sometimes, explicitly, showing where their network is not delivering as "promised" sometimes does wonders too.)
An ISP can causes issues, even when they (almost always) say, it's not them.  (Don't misunderstand, most of the time it's not them, but not always.)
Because of possible ISP issues, I earlier wrote "Do either of your site's physical Internet connections have a ISP bandwidth cap, in and/or out?"
This wasn't yet to imply an actual issue with your ISP, but just an initial item opening the door to considering the ISP aspect.
We were about to go the route of switching ISPs as well, but after our 3rd ticket with the carrier I finally got a good technician who worked with us and found the following:
https://www.lumen.com/help/en-us/network/resolving-throughput-issues.html
If your ISP is dealing with a separate carrier for the last mile, there is a chance this could be happening and was causing reordering of packets for us due to a hashing issue between provider protocols.  Very strange, indeed but finding this answer helped my sanity!
Cisco TAC pretty much confirmed the reordering with some captures and ruled out our equipment.
