throughput Router Cisco 2900 and 3900
mandres01
i like know that throughput router cisco 2900 and 3900...
thanks so much...
Ohhhh ... You want PPS?  You didn't say so.
Look here:  https://supportforums.cisco.com/thread/2197539
5 Replies 5
Leo Laohoo
• The Cisco 2900 Series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps.
• The Cisco 3900 Series enables deployment in high-speed WAN environments with concurrent services enabled up to 350 Mbps.
• The Cisco 4451-X enables deployment in high-speed WAN environments with concurrent services enabled up to 2Gbps.
the explanation would 75 mega bits per second? i need know the packets per second that process this router..
thank so much for answer...
thank so much....
