Password recovery on a Catalyst 3850 switch
kelayrel_
Forgive the newbie question, but I'm trying to do password recovery on a Catalyst 3850 switch, and I can't figure out what I have to actually *do*.
I've read the section in this: http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3.2_0_se/security/configuration_guide/b_sec_1501_3850_cg_chapter_011.html#concept_8DD2D3858A774C2798D30927F5761C66
where it says that I need to have physical access to the switch (I do), and that I reset the password if I issue a break command and interrupt the boot procedure. I've tried to do that... it gives me the "switch:" prompt, so I think I've interrupted the boot procedure successfully, but, what do I do next?
I've successfully done recoveries on Catalyst 2950s, 3550s & 3560s, but the procedure for this one, if I'm reading the link above right, sounds like it's completely different.
There's no config on this switch, at least, nothing that can't be wiped if it needs to be.
Thanks for the help!
-Jen
11 Replies 11
mfurnival
Level 4
Level 4
Have you tried the usual password recovery method?
switch: flash_init
switch: load_helper
switch: rename flash:config.text flash:config.old
switch: boot
I have... there doesn't appear to be a "config.text" file in the flash: directory, and it's giving me an unknown cmd error on load_helper.
Just reading up on this and realised it is XOS. Can you do a dir flash: ?
I was trying to find info for password recovery on XOS and there does not seem to be much out there!
I've noticed! *lol* What I've found about resetting passwords seems to assume you're in priveledged EXEC already - which would be part of the problem, really.
I can do a dir flash:. This is what I get:
54209  drwx  4096       .
    2  drwx  4096       ..
54210  -rw-  2097152    nvram_config
54211  -rw-  74410468   cat3k_caa-base.SPA.03.02.00SE.pkg
54212  -rw-  2773680    cat3k_caa-drivers.SPA.03.02.00.SE.pkg
54213  -rw-  32478044   cat3k_caa-infra.SPA.03.02.00SE.pkg
54214  -rw-  30393116   cat3k_caa-iosd-universalk9.SPA.150-1.EX.pkg
54215  -rw-  18313952   cat3k_caa-platform.SPA.03.02.00.SE.pkg
54216  -rw-  63402700   cat3k_caa-wcm.SPA.10.0.100.0.pkg
54217  -rw-  1218       packages.conf
54218  -rw-  556        vlan.dat
54219  -rw-  57         express_setup.debug
Not sure if that helps at all.
It might be the "nvram_config" that you need to rename. This is guesswork on my part though - if it goes wrong and your switch bursts into flames I assume no responsibility.
Was worth a shot... unfortunately, it won't let me copy/rename that file as it's read only, apparently. The permissions don't look like that... but when I do this, I get the following error:
switch: copy flash:nvram_config flash:nvram_config.old
flash:nvram_config.old: read only file system
Assuming I did that right to begin with (did I mention I'm pretty new to all of this? Heh.), do you know of any way I can work around that and try to do it anyway?
Can you do a "?" at the switch: prompt to see what commands are available?
I am assuming that you did the "flash_init" before trying the rename command?
I did. Flash was already initialized. I get the same error when I do a rename flash:nvram_config flash:nvram_config.old, as well. Read only file system.
When I do a ?, the command list it gives me is this:
switch: ?
           ? -- Present list of available commands
         arp -- Show arp table or arp-resolve an address
        boot -- Load and boot an executable image
         cat -- Concatenate (type) file(s)
        copy -- Copy a file
      delete -- Delete file(s)
         dir -- List files in directories
emergency-install -- Initiate Disaster Recovery
  flash_init -- Initialize filesystem(s)
      format -- Format a filesystem
        fsck -- Check filesystem consistency
        help -- Present list of available commands
   mgmt_init -- initialize management port
       mkdir -- Create dir(s)
        more -- Concatenate (display) file(s)
        ping -- Send ICMP ECHO_REQUEST packets to a network host
      rename -- Rename a file
       reset -- Reset the system
       rmdir -- Delete empty dir(s)
         set -- Set or display environment variables
      set_bs -- Set attributes on a boot sector filesystem
   set_param -- Set system parameters in flash
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
Any thoughts?
set_bs looks interesting. So does emergency-install...
I am just guessing now...
FWLIW, the "emergency-install tftp://ip/IOSImageName.bin" seems to erase flash, load a minimal image (like the old load_helper) and then pull down the entire image ... this became important for me recovering from a dead-in-the-water 3850 ... HTH!
/TJ
kelayrel_
My god, I actually managed to find it! Yay internet!
For those who may be looking for help on password recovery for the 3850 switch in the future, I'll post what I found. I ended up resetting the switch because, well, easier.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/hardware/quick/guide/cat3850_gsg.html#wp46478 - reset procedures found here
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3.2_0_se/system_management/configuration_guide/b_sm_32se_3850_cg_chapter_010001.html#concept_6E610BCFF5174E498454F09CB6489799
-this has a password recovery procedure that... sort of worked for me (but not completely, thus my choosing to reset rather than fiddle with it).
Hope that's helpful to someone else down the line!
-Jen
