timeslots
amenash123
hi
i have this following configuratio:
controller E1 1/0
channel-group 5 timeslots 5-8
channel-group 6 timeslots 1-4
channel-group 7 timeslots 17
channel-group 9 timeslots 9-10
channel-group 11 timeslots 11-14
channel-group 13 timeslots 16
channel-group 14 timeslots 18-19
channel-group 15 timeslots 20-21
channel-group 16 timeslots 22-23
channel-group 17 timeslots 24-25
channel-group 18 timeslots 26-29
channel-group 19 timeslots 30
channel-group 20 timeslots 31
and i would like to know how much timeslots i have? and how much inter serial i can to config.
thanks.
barisal
Hi;
Except from timeslot 15 all of them are used in your configuration. You may count to find the result. Besides this, 128 logical serial interfaces can be configured on a PA-MC-8E1 port adapter.
Baris.
for an E1 controller, the time slots range from 1 to 31, channel-group numbers can be values from 0 to 30.
and the number of serial (sub)interfaces is the same, 31 (1-31), one of which, 15, is the D-channel interface.
HTH,
GP
