Timestamp ping option - solicit
lorenzomot
Frequent Visitor
Frequent Visitor
Hello everyone,
i was wondering if there is a method to have a verbose output of the ping with the timestamp related.
As you can see, i mean an output like this:
14:35:43 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=1 ttl=54 time=20 ms
14:35:44 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=2 ttl=54 time=22 ms
14:35:44 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=3 ttl=54 time=19 ms
14:35:45 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=4 ttl=54 time=20 ms
14:35:45 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=5 ttl=54 time=20 ms
Trying to search in the extend command filed of the ping options, i found this:
Loose, Strict, Record, Timestamp, Verbose[none]: timestamp
So i compiled the information like this:
ping
Protocol [ip]:
Target IP address: 8.8.8.8
Repeat count [5]: 1000
Datagram size [100]: 1400
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Number of timestamps [ 9 ]:
Loose, Strict, Record, Timestamp, Verbose[TV]:
Sweep range of sizes [n]:
Sending 1000, 1400-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet has IP options:  Total option bytes= 40, padded length=40
Timestamp: Type 0.  Overflows: 0 length 40, ptr 5
  >>Current pointer<<
  Time= 02:00:00.000 summertime (00000000)
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
Request 5 timed out
Request 6 timed out
Request 7 timed out
Request 8 timed out
Request 9 timed out
Request 10 timed out
The output is not what i wanted.
I don't know what to insert as value Number of timestamps. I left it as the standard (9) but the result is strange. Moreover the ping failed.
Can anyone help me?
Thank you so much for the support.
Bye
Lorenzo
To my knowledge, there is no way to do that. You could do something with ACL logging, or debug is packet detail to get a time stamp. What are you trying to accomplish?
Please mark helpful posts.
5 Replies 5
Alex Pfeil
Level 10
Level 10
Timestamp is used to measure roundtrip time to particular hosts. It is not used to put the time of the ping.
Please rate helpful posts.
Hello Alex, Thank you. Can you please show me an example?
Is there another way to have an output like the one mentioned above?
Thank you
I need to keep a ping open for hours and need to know at what specific minute and seconds it dropped packets, whether it drops 🙂
By the way thank you
Lorenzo
You can use an IP SLA. You can then see what time the last time that it failed was. You can also setup some free ping monitoring tools that will do this from a computer or server. You would just search for free ping monitor and there are a few. One of them definitely will tell you when it failed.
Thanks!
