ASR 920 not handing out IP addresses
Ducati0927
I have a feeling that I am missing something very basic in this but I am not able to get my 920 to hand out an IP to any device I connect to it.  ISP will be coming in on Gi0/0/5 and connected to my 2960-x on Port Gi0/0/10. Can anyone take a peek and see if they see the issue.  Sorry for the basic question.
! Last configuration change at 11:06:44 UTC Sat Oct 13 2018
version 15.5
no service pad
no platform punt-keepalive disable-kernel-core
platform bfd-debug-trace 1
platform tcam-parity-error enable
platform tcam-threshold alarm-frequency 1
hostname TheCloudCore
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
facility-alarm critical exceed-action shutdown
ip dhcp excluded-address 10.0.1.150
ip dhcp pool TheCloud
network 10.0.1.0 255.255.255.0
dns-server 1.1.1.1 1.0.0.1 8.8.8.8
domain-name myccnalab.ddns.net
default-router 10.0.1.1 255.255.255.0
lease 2
license feature port bulk
license udi pid ASR-920-12CZ-A sn xxxxxxxxxxx
license boot level metroipaccess
sdm prefer default
redundancy
transceiver type all
monitoring
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface GigabitEthernet0/0/3
no ip address
negotiation auto
interface GigabitEthernet0/0/4
no ip address
media-type auto-select
negotiation auto
interface GigabitEthernet0/0/5
ip address dhcp
media-type rj45
negotiation auto
interface GigabitEthernet0/0/6
no ip address
negotiation auto
interface GigabitEthernet0/0/7
no ip address
negotiation auto
interface GigabitEthernet0/0/8
no ip address
negotiation auto
interface GigabitEthernet0/0/9
no ip address
negotiation auto
interface GigabitEthernet0/0/10
no ip address
media-type rj45
negotiation auto
interface GigabitEthernet0/0/11
no ip address
negotiation auto
interface TenGigabitEthernet0/0/12
no ip address
interface TenGigabitEthernet0/0/13
no ip address
vrf forwarding Mgmt-intf
no ip address
negotiation auto
ip default-gateway 10.0.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Still Learning thank you for all the help.
Will G
balaji.bandi
Quick Test here :
If ASR acting as DHCP Server
Interface Gi0/0/10   <- as per your description this is connected to your 2900 switch.
ip address 10.0.1.1 255.255.255.0
no shutdown
i am in a assumption that 2960 no VLAN config done. so default vlan1.
So PC should get ip address from 10.10.1.2
If this router acting as internet NAT translation, your default route point to ISP.
Test and let me know, also post full config of the switch.
BB
Alex Pfeil
Level 7
Level 7
You need to configure the default gateway that DHCP will hand out on the ASR. The ASR will be the default gateway.
balaji.bandi
Quick Test here :
no shutdown
BB
