Too slow to initiate SSL VPN from Anyconnect to an ASA 5515 Essential SSL VPN gateway
gcgwwm2010
I have setup a ssl vpn gateway on the ASA. The problem is when I first time to initiate a ssl vpn connection from anyconnect client, it will take 1 to 2 minutes. But after that, if I disconnect or cancel it and reconnect to it, it will take only 5 seconds.
The message history on the client shows
[09/07/2015 11:41:56 AM] Ready to connect.
[09/07/2015 11:43:49 AM] Contacting VPNGateway.
[09/07/2015 11:43:50 AM] Please enter your username and password.
[09/07/2015 11:46:49 AM] User credentials prompt cancelled.
[09/07/2015 11:46:49 AM] Ready to connect.
[09/07/2015 11:46:56 AM] Contacting VPNGateway.
[09/07/2015 11:46:57 AM] Please enter your username and password.
Please anyone to share your expertise on this or the similar issues.
0 Replies 0
