Tool Design
stephtchoko
Level 3
Level 3
Good day, i send a command of cisco 2811 for vopi to my cisco network reseller .And he says me that PVDM module is require.
Where can i find all element require (daughter card, ios etc..) to deploy a solution ??
Best regards.
5 Replies 5
spremkumar
Level 9
Level 9
If you want to check out for the compatiability and the avl of inerface modules and wics do check this link out..
http://www.cisco.com/en/US/products/hw/modules/prod_module_category_home.html
for software advisory and feature navigation do refer this link ..
http://www.cisco.com/kobayashi/support/tac/tools.shtml
regds
i can't access to second module.I don't know why.
Best regards.
You need to have CCO id with enough privileges to access that link ,which contain enough useful links which may help u out..
regds
How can i obtain it this CCO please ?
rgds.
you need to have either one of these required codes to get the additional prviliege required to acces those kinda links..
Cisco Channel Partner or Authorized Reseller
Direct Purchase
Obtain access to additional service contract(s)
Cisco Certified Internetwork Expert [CCIE User]
regds
