Top 5 IP routing addresses list when interface port are almost full
eeebbunee
Level 3
Level 3
Hello All,
When we are using limited bandwidth, sometimes we faced on interface port is almost full.
I would like to know Top usage IP address list when the network is full state. Is there any commend line for L3 switch?
(I am using C3750X stacks)
Furthermore, I would like to keep the history during the night time using Zabbix NMS server.
Please share me your precious advice. Thank you.
balaji.bandi
As per the information you need Netflow to get this information, but we are not sure what full model of the switch and got Module and what version of IOS code running?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html
https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/fnetflow/configuration/15-sy/fnf-15-sy-book/cgf-topn.html.xml
BB
for the 3750X switches you need a network services module that supports Flexible Netflow (FNF), you also need IP Base or IP Services, as LAN Base or NPE don't support it.
Post the output of 'sh ver' of one of your stack switches...
Giuseppe Larosa
Hello @eeebbunee ,
you need the appropriate hardware to run Netflow on the uplink module that supports it
I may be wrong but netflow on these type of switch is supported only on ports of the uplink module that supports netflow not on the standard ports.
Hope to help
Giuseppe
