Total ouput drops on a router.
simon.dwyer
Hi All,
I have a Router that connects to a IP WAN.
Its a over subscribed link by a fair bit.  This router has a 4mbit link to the WAN while the sum of other sites are well over 20mbit.
I have configured HQF on the outbound of the router and bumped up the hold-queue because the sum of queue spots on my qos rules reached over 1000.
My question is that if HQF drops a packet because of shaping will it appear on the show int as "Total output drops"?
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0025.4540.67b0 (bia 0025.4540.67b0)
  Internet address is 192.168.200.33/30
  MTU 1500 bytes, BW 4096 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 102/255, rxload 26/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 15:57:14
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 29208
  Queueing strategy: Class-based queueing
  Output queue: 41/8096/0 (size/max total/drops)
  30 second input rate 422000 bits/sec, 305 packets/sec
  30 second output rate 1646000 bits/sec, 396 packets/sec
     12186897 packets input, 3364350770 bytes
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog
     14074754 packets output, 2145701571 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
interface FastEthernet0/0
bandwidth 4096
ip address x x
ip flow ingress
ip flow egress
ip ospf 1 area 0
load-interval 30
tx-ring-limit 3
tx-queue-limit 3
speed 100
full-duplex
no cdp enable
service-policy output Master
hold-queue 8096 out
end
Cheers,
Simon
paolo bevilacqua
Check and compare with the output of "show policy ".
NG-SR-WE-RT-2#show policy-map int fa0/0
FastEthernet0/0
  Service-policy output: Master
    Class-map: class-default (match-any)
      14456462 packets, 6633389318 bytes
      30 second offered rate 480000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 128 packets
      (queue depth/total drops/no-buffer drops) 6/29660/0
      (pkts output/bytes output) 14317890/6578999930
      shape (average) cir 3700000, bc 14800, be 14800
      target shape rate 3700000
      Service-policy : Main
        Class-map: site1 (match-any)
          2100251 packets, 710542995 bytes
          30 second offered rate 33000 bps, drop rate 0 bps
          Match: access-group name Strahan
            2100251 packets, 710543265 bytes
            30 second rate 33000 bps
          Queueing
          queue limit 64 packets
          (queue depth/total drops/no-buffer drops) 0/2338/0
          (pkts output/bytes output) 2071818/704852585
          shape (average) cir 2000000, bc 8000, be 8000
          target shape rate 2000000
          Service-policy : Classes
            Class-map: Silver (match-all)
              0 packets, 0 bytes
              30 second offered rate 0 bps, drop rate 0 bps
              Match:  dscp af21 (18)
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
              (pkts output/bytes output) 0/0
              bandwidth 25% (38 kbps)
              Fair-queue: per-flow queue limit 16
            Class-map: Gold (match-all)
              187678 packets, 65414569 bytes
              30 second offered rate 2000 bps, drop rate 0 bps
              Match:  dscp af31 (26)
              Queueing
              (pkts output/bytes output) 187681/65416697
              bandwidth 30% (46 kbps)
            Class-map: Scavanger (match-any)
              309036 packets, 248342370 bytes
              30 second offered rate 4000 bps, drop rate 0 bps
              Match:  dscp af11 (10)
                156644 packets, 143705694 bytes
                30 second rate 2000 bps
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                30 second rate 0 bps
              Match: access-group name WebTraffic
                152392 packets, 104636676 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1045/0/1045
              (pkts output/bytes output) 307991/246945249
              bandwidth 5% (7 kbps)
              1602417 packets, 396664374 bytes
              30 second offered rate 25000 bps, drop rate 0 bps
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1416/0/1416
              (pkts output/bytes output) 1601000/394917473
        Class-map: site2 (match-all)
          2299692 packets, 447799900 bytes
          30 second offered rate 112000 bps, drop rate 0 bps
          Match: access-group name Freycinet
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1796/0
          (pkts output/bytes output) 2287384/444688272
          shape (average) cir 400000, bc 1600, be 1600
          target shape rate 400000
              0 packets, 0 bytes
              Queueing
              90496 packets, 30432777 bytes
              Queueing
              (pkts output/bytes output) 90496/30432777
              1318302 packets, 186789408 bytes
              30 second offered rate 85000 bps, drop rate 0 bps
                1283396 packets, 160960268 bytes
                30 second rate 57000 bps
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                34906 packets, 25829140 bytes
                30 second rate 31000 bps
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1311/0/1311
              (pkts output/bytes output) 1317004/186027693
              890269 packets, 230474321 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/486/0/486
              (pkts output/bytes output) 889785/229869026
        Class-map: site3 (match-all)
          1095647 packets, 432669708 bytes
          30 second offered rate 23000 bps, drop rate 0 bps
          Match: access-group name Saffire
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1719/0
          (pkts output/bytes output) 1080265/428516633
          shape (average) cir 900000, bc 3600, be 3600
          target shape rate 900000
              0 packets, 0 bytes
              Queueing
              76519 packets, 16886845 bytes
              30 second offered rate 7000 bps, drop rate 0 bps
              Queueing
              (pkts output/bytes output) 76519/16886845
              277338 packets, 262250310 bytes
              30 second offered rate 1000 bps, drop rate 0 bps
                201236 packets, 197880101 bytes
                30 second rate 1000 bps
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                76102 packets, 64370209 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1548/0/1548
              (pkts output/bytes output) 275791/260316777
              740973 packets, 153414997 bytes
              30 second offered rate 13000 bps, drop rate 0 bps
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/180/0/180
              (pkts output/bytes output) 740797/153199296
        Class-map: site4 (match-all)
          41664 packets, 4590063 bytes
          Match: access-group name CradleMountainCafe
          Queueing
          (queue depth/total drops/no-buffer drops) 0/49/0
          (pkts output/bytes output) 39811/4325558
          shape (average) cir 600000, bc 2400, be 2400
          target shape rate 600000
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              82 packets, 20014 bytes
                52 packets, 9093 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                30 packets, 10921 bytes
              Queueing
              (pkts output/bytes output) 82/20014
              41478 packets, 4558825 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/49/0/49
              (pkts output/bytes output) 41429/4489091
        Class-map: site5 (match-all)
          1408719 packets, 350645119 bytes
          30 second offered rate 36000 bps, drop rate 0 bps
          Match: access-group name CradleMountainChateau
          Queueing
          (queue depth/total drops/no-buffer drops) 0/880/0
          (pkts output/bytes output) 1404488/349176866
          shape (average) cir 450000, bc 1800, be 1800
          target shape rate 450000
              0 packets, 0 bytes
              Queueing
              106022 packets, 37679967 bytes
              30 second offered rate 10000 bps, drop rate 0 bps
              Queueing
              (pkts output/bytes output) 106022/37679967
              171531 packets, 104937156 bytes
                134747 packets, 72722781 bytes
                30 second rate 4000 bps
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                36784 packets, 32214375 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/339/0/339
              (pkts output/bytes output) 171192/104450979
              1131027 packets, 208013822 bytes
              30 second offered rate 21000 bps, drop rate 0 bps
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/541/0/541
              (pkts output/bytes output) 1130486/207347924
        Class-map: site6 (match-all)
          425248 packets, 150256922 bytes
          30 second offered rate 11000 bps, drop rate 0 bps
          Match: access-group name Queenstown
          Queueing
          (queue depth/total drops/no-buffer drops) 0/149/0
          (pkts output/bytes output) 424348/150031574
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              34327 packets, 18478904 bytes
                25831 packets, 13227562 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                8496 packets, 5251342 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/29/0/29
              (pkts output/bytes output) 34298/18441262
              390867 packets, 131773898 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/120/0/120
              (pkts output/bytes output) 390747/131646802
        Class-map: site7 (match-all)
          434070 packets, 129465505 bytes
          30 second offered rate 24000 bps, drop rate 0 bps
          Match: access-group name Sydney
          Queueing
          (queue depth/total drops/no-buffer drops) 0/73/0
          (pkts output/bytes output) 431489/129124946
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              70115 packets, 46097575 bytes
                7887 packets, 1957279 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                62228 packets, 44140296 bytes
                30 second rate 7000 bps
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/24/0/24
              (pkts output/bytes output) 70091/46067011
              363806 packets, 83353388 bytes
              30 second offered rate 18000 bps, drop rate 0 bps
              Match: any
              Queueing
              (pkts output/bytes output) 363757/83293841
        Class-map: V-KP (match-all)
          123876 packets, 56542454 bytes
          Match: access-group name V-KP
          Queueing
          (queue depth/total drops/no-buffer drops) 0/305/0
          (pkts output/bytes output) 121185/55780221
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              33659 packets, 39051647 bytes
                29912 packets, 35908904 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                3747 packets, 3142743 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1/0/1
              (pkts output/bytes output) 33658/39050213
              90086 packets, 17477681 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/336/0/336
              (pkts output/bytes output) 89750/17000672
        Class-map: V-SI (match-all)
          499530 packets, 369252332 bytes
          30 second offered rate 37000 bps, drop rate 0 bps
          Match: access-group name V-SI
          Queueing
          (queue depth/total drops/no-buffer drops) 6/1848/0
          (pkts output/bytes output) 495118/366488272
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              163580 packets, 202750793 bytes
              30 second offered rate 15000 bps, drop rate 0 bps
                141501 packets, 193053607 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                22079 packets, 9697186 bytes
                30 second rate 15000 bps
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 5/317/0/317
              (pkts output/bytes output) 163266/202350675
              335810 packets, 166487588 bytes
              30 second offered rate 19000 bps, drop rate 0 bps
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1561/0/1561
              (pkts output/bytes output) 334249/164436314
        Class-map: V-WH (match-all)
          272905 packets, 136712628 bytes
          Match: access-group name V-WH
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1226/0
          (pkts output/bytes output) 268880/134585731
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              80819 packets, 65884546 bytes
                53346 packets, 61161662 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                27473 packets, 4722884 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/32/0/32
              (pkts output/bytes output) 80787/65840880
              191851 packets, 70795512 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1264/0/1264
              (pkts output/bytes output) 190587/69097889
        Class-map: V-SL (match-all)
          252062 packets, 149304552 bytes
          30 second offered rate 12000 bps, drop rate 0 bps
          Match: access-group name V-SL
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1137/0
          (pkts output/bytes output) 248761/147554111
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              74969 packets, 88706011 bytes
              30 second offered rate 5000 bps, drop rate 0 bps
                69562 packets, 85196978 bytes
                30 second rate 5000 bps
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                5407 packets, 3509033 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/84/0/84
              (pkts output/bytes output) 74885/88598985
              176965 packets, 60586065 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1053/0/1053
              (pkts output/bytes output) 175913/59159596
        Class-map: V-VH (match-all)
          287171 packets, 142961909 bytes
          Match: access-group name V-VH
          Queueing
          (queue depth/total drops/no-buffer drops) 0/922/0
          (pkts output/bytes output) 282802/141181910
              0 packets, 0 bytes
              Queueing
              227 packets, 145415 bytes
              Queueing
              (pkts output/bytes output) 227/145415
              63463 packets, 65451135 bytes
                58014 packets, 61841722 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                5449 packets, 3609413 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/17/0/17
              (pkts output/bytes output) 63446/65426517
              223329 packets, 77350583 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/936/0/929
              (pkts output/bytes output) 222400/75981808
        Class-map: V-HT (match-all)
          797021 packets, 751618244 bytes
          Match: access-group name V-HT
          Queueing
          (queue depth/total drops/no-buffer drops) 0/2091/0
          (pkts output/bytes output) 792584/748538061
              0 packets, 0 bytes
              Queueing
              20030 packets, 4515447 bytes
              Queueing
              (pkts output/bytes output) 20030/4515447
              517358 packets, 670118225 bytes
                502508 packets, 658696420 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                14850 packets, 11421805 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/473/0/473
              (pkts output/bytes output) 516885/669475271
              259506 packets, 76972146 bytes
              30 second offered rate 17000 bps, drop rate 0 bps
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1618/0/1618
              (pkts output/bytes output) 257888/74765447
        Class-map: V-SO (match-all)
          304933 packets, 171719882 bytes
          Match: access-group name V-SO
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1007/0
          (pkts output/bytes output) 301818/170056835
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              90015 packets, 106405507 bytes
                70009 packets, 87664620 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                20006 packets, 18740887 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/243/0/243
              (pkts output/bytes output) 89772/106068723
              214794 packets, 65302291 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/764/0/764
              (pkts output/bytes output) 214030/64187960
        Class-map: V-FU (match-all)
          378134 packets, 237453147 bytes
          30 second offered rate 6000 bps, drop rate 0 bps
          Match: access-group name V-FU
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1021/0
          (pkts output/bytes output) 374951/235852719
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              147133 packets, 159213350 bytes
                116691 packets, 155003853 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                30442 packets, 4209497 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/111/0/111
              (pkts output/bytes output) 147022/159073222
              230868 packets, 78226564 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/910/0/910
              (pkts output/bytes output) 229958/76983462
        Class-map: V-DT (match-all)
          481384 packets, 295901655 bytes
          Match: access-group name V-DT
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1029/0
          (pkts output/bytes output) 477594/294116348
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              153182 packets, 171831569 bytes
                119490 packets, 151385364 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                33692 packets, 20446205 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/130/0/130
              (pkts output/bytes output) 153052/171658705
              328046 packets, 124054996 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/943/0/941
              (pkts output/bytes output) 327105/122786662
        Class-map: V-GW (match-all)
          223195 packets, 87892888 bytes
          Match: access-group name V-GW
          Queueing
          (queue depth/total drops/no-buffer drops) 0/518/0
          (pkts output/bytes output) 217014/86733063
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              52376 packets, 57101095 bytes
                36712 packets, 40168644 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                15664 packets, 16932451 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/87/0/87
              (pkts output/bytes output) 52289/56980016
              170468 packets, 30758821 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/483/0/483
              (pkts output/bytes output) 169986/30267322
        Class-map: V-CH (match-all)
          862578 packets, 817365461 bytes
          30 second offered rate 8000 bps, drop rate 0 bps
          Match: access-group name V-CH
          Queueing
          (queue depth/total drops/no-buffer drops) 0/4386/0
          (pkts output/bytes output) 848168/810486795
              0 packets, 0 bytes
              Queueing
              23302 packets, 4598897 bytes
              Queueing
              (pkts output/bytes output) 23302/4598897
              451361 packets, 648522265 bytes
                445763 packets, 645321347 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                5598 packets, 3200918 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/2835/0/2824
              (pkts output/bytes output) 448535/644730440
              387758 packets, 164217395 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1580/0/1580
              (pkts output/bytes output) 386178/161959473
        Class-map: V-HF (match-all)
          274060 packets, 150605569 bytes
          Match: access-group name V-HF
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1339/0
          (pkts output/bytes output) 270488/148528040
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              92362 packets, 89967909 bytes
                67972 packets, 85884455 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                24390 packets, 4083454 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/126/0/126
              (pkts output/bytes output) 92235/89799473
              181557 packets, 60623692 bytes
              30 second offered rate 9000 bps, drop rate 0 bps
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1213/0/1213
              (pkts output/bytes output) 180344/58939576
        Class-map: V-EH (match-all)
          579312 packets, 298149985 bytes
          Match: access-group name V-EH
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1421/0
          (pkts output/bytes output) 574797/295786243
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              130800 packets, 147474635 bytes
                116388 packets, 141157763 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                14412 packets, 6316872 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/89/0/89
              (pkts output/bytes output) 130711/147361341
              448305 packets, 150644898 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1371/0/1371
              (pkts output/bytes output) 446934/148777471
        Class-map: V-MM (match-all)
          448873 packets, 389566414 bytes
          30 second offered rate 52000 bps, drop rate 0 bps
          Match: access-group name V-MM
          Queueing
          (queue depth/total drops/no-buffer drops) 0/2348/0
          (pkts output/bytes output) 444347/385977494
              0 packets, 0 bytes
              Queueing
              4190 packets, 1211744 bytes
              Queueing
              (pkts output/bytes output) 4190/1211744
              227218 packets, 325747760 bytes
                225689 packets, 325108122 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                1529 packets, 639638 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1563/0/1563
              (pkts output/bytes output) 225655/323499765
              217330 packets, 62593530 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/785/0/785
              (pkts output/bytes output) 216545/61471496
        Class-map: V-JL (match-all)
          225705 packets, 137954107 bytes
          Match: access-group name V-JL
          Queueing
          (queue depth/total drops/no-buffer drops) 0/338/0
          (pkts output/bytes output) 223224/137306409
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              61509 packets, 84689364 bytes
                60596 packets, 84382093 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                913 packets, 307271 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/92/0/92
              (pkts output/bytes output) 61417/84583824
              164069 packets, 53252099 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/246/0/246
              (pkts output/bytes output) 163823/52925347
        Class-map: V-MK (match-all)
          387206 packets, 176569431 bytes
          Match: access-group name V-MK
          Queueing
          (queue depth/total drops/no-buffer drops) 0/1705/0
          (pkts output/bytes output) 383338/173990899
              0 packets, 0 bytes
              Queueing
              0 packets, 0 bytes
              Queueing
              124883 packets, 99161606 bytes
                88309 packets, 89980446 bytes
              Match:  dscp cs1 (8)
                0 packets, 0 bytes
                36574 packets, 9181160 bytes
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/104/0/104
              (pkts output/bytes output) 124779/99028211
              262197 packets, 77395497 bytes
              Match: any
              Queueing
              (queue depth/total drops/no-buffer drops/flowdrops) 0/1601/0/1601
              (pkts output/bytes output) 260596/75167578
          253231 packets, 37848178 bytes
          30 second offered rate 3000 bps, drop rate 0 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/15/0/15
          (pkts output/bytes output) 253216/35317717
