Trace BGP peering interface
anitachoi3
Hi expert,
I would like to announce "ip address 10" to ISP B when the interface EF0/0 is down. Grateful if you could advise how to do it. The trace commands are in the configuration file as below.
Thank you
--- configuration ------
track 1 interface FE0/0 line-protocol
! track 2 interface serial1/1 line-protocol
! track 3 interface serial1/2 line-protocol
track 100 list threshold percentage
object 1
! object 2
! object 3
! object 4
threshold percentage up 80
interface FE 0/0
description IPS A (AS1)
ip address 10.10.10.2 255.255.255.0
interface FE 0/1
description IPS B (AS3)
ip address 10.10.20.2 255.255.255.0
router bgp 10
bgp log-neighbor-changes
network 192.168.16.0 255.255.240.0
neighbor 10.10.10.1 remote-as 1
neighbor 10.10.10.1  route-map ROUTES_TO_ISP_A out
neighbor 10.10.20.3 remote-as 3
neighbor 10.10.20.3  route-map ROUTES_TO_ISP_B out
neighbor 10.10.20.3 advertise-map ADVERTISE non-exist-map NON-EXIST
!--- Advertises the routes matched in the route-map ADVERTISE (192.168.16, 192.168.24 and 192.168.28)
!--- only if the routes matched in route-map NON-EXIST (192.168.50.0/24)
!--- do not exist in the BGP table.
ip route 192.168.16.0 255.255.240.0 Null0
! Route Condition
access-list 65 permit 192.168.50.0 0.0.0.255
! announce routes to ISP A only
access-list 10 permit 192.168.16.0 0.0.7.255
access-list 10 permit 192.168.24.0 0.0.3.255
access-list 10 permit 192.168.28.0 0.0.1.255
! announce routes to ISP B only
access-list 15 permit 192.168.30.0 0.0.1.255
ip as-path access-list 400 deny .*
route-map NON-EXIST permit 10
match ip address 65
route-map ADVERTISE permit 10
match ip address 10
route-map ROUTES_TO_ISP_A permit 10
match ip address 10
route-map ROUTES_TO_ISP_A permit 20
match as-path 400
route-map ROUTES_TO_ISP_B permit 10
match ip address 15
route-map ROUTES_TO_ISP_B permit 20
match as-path 400
---- end -----
Hi  Anita
Try this one ........
interface FE 0/0
description ISP A (AS1)
interface FE 0/1
description ISP B (AS3)
router bgp 10
neighbor 10.10.20.3 advertise-map ROUTES_TO_ISP_A non-exist-map NO_ROUTE
-----Advertise to ISP A -------
-----Advertise to ISP B -------
access-list 20 permit 10.10.10.0 0.0.0.255
match address 10
match address 15
route-map NO_ROUTE
match address 20
Chetan Kumar
5 Replies 5
Mohamed Sobair
Level 7
Level 7
Your configuration should look lik this:
interface FE 0/0
interface FE 0/1
router bgp 10
network 10.10.20.0 mask 255.255.255.0
ip prefix-list advertise permit 10.10.20.0/24
Note:
your route-map (ROUTES_TO_ISP_B) should include Network 10.10.2.0
ip perefix-list NON-EXIST permit 10.10.10.2/24
route-map ADVERTISE
match ip address prefix-list ADVERTISE
route-map NON-EXIST
match ip address prefix-list NON-EXIST
Note:
Your route-map (ROUTES_TO_ISP_B) should include Network 10.10.20.0/24 in another sequence number in order for this network not to be filtered when its being advertised to ISP-B by the route-map.
Mohamed
Dear Mohamed,
My preceding email may be vague. Following is the user requirements:
- 192.168.16.0/21, 192.168.24.0/22, 192.168.28/23 are down stream network behind AS 2. They will be announced to ISP A only
- 192.168.30.0/23 is down stream network behind AS 2. They will be announced to ISP B only
- If ISP A down, the routes 192.168.16.0/21, 192.168.24.0/22, 192.168.28/23 will be announced to ISP B. If ISP A is up again, the routes 192.168.16.0/21, 192.168.24.0/22, 192.168.28/23 will be withdrawn from ISP B and announced to ISP A.
I have revised the config for your comments
Thank you
------ config ------
interface FE 0/0
interface FE 0/1
router bgp 10
network 192.168.16.0 mask 255.255.240.0
!--- only if the routes matched in route-map NON-EXIST (10.10.10.0/24)
! Route Condition
ip perefix-list NON-EXIST permit 10.10.10.0/24
! ip prefix-list ADVERTISE permit 10.10.20.0/24
access-list 25 permit 10.10.20.0 0.0.0.255
route-map ADVERTISE
! match ip address prefix-list ADVERTISE
match ip address 10
route-map NON-EXIST
match ip address 10 20
match as-path 400
match ip address 15 25
match as-path 400
---- end -----
Hi  Anita
interface FE 0/0
interface FE 0/1
router bgp 10
match address 10
match address 15
route-map NO_ROUTE
match address 20
Chetan Kumar
Hi Chetan Kumar,
One more question, if the FE 0/0 is down, the route (direct connect) 10.10.10.0/24 will be withdrawn from the routing table. Is it correct?
rdgs
Hi Anita
Yes , If you physical interface goes down then you won't see the route in routing table.
Chetan Kumar
