Traceback messages on Cisco ISR 2800 router
ryabutler
Can someone provide input on what these Traceback messages are and how they are caused:
*Mar 15 23:07:57.250: %SERVICE_MODULE-4-WICNOTREADY: Unit Serial0/1/0 not ready for next command -Traceback= 0x41173B5C 0x40371894 0x40371928 0x40371CE0 0x40372794
0x40369AF0 0x40382908 0x4037FEB4 0x4037FF80 0x41EF56B4 0x41EF95E4 0x41EEA51C 0x41F12B00 0x42183F44 0x42183F28
*Mar 15 23:08:00.250: %SERVICE_MODULE-4-WICNOTREADY: Unit Serial0/1/0 not ready for next command -Traceback= 0x41173B5C 0x40371894 0x40371928 0x40371CE0 0x40372794
*Mar 15 23:08:03.250: %SERVICE_MODULE-4-WICNOTREADY: Unit Serial0/1/0 not ready for next command -Traceback= 0x41173B5C 0x40371894 0x40371928 0x40371CE0 0x40372794
.... and so on.
We recieved this for one of our routers.  Rebooting it worked, so it's likely a software bug and we will upgrade the IOS soon, but I would like to understand what these log messages.
Thanks in advanced!
6 Replies 6
Giuseppe Larosa
Hello RyaButler,
the only meaningful message for  human beings is :
this means the WIC is not considered usable.
Tracebacks are low level messages that only IOS developers can decode with their tools. As you noted this should be a SW bug if the card works.
Hope to help
Giuseppe
Leo Laohoo
Or the WIC is not seated properly or s_c_r_e_wed in properly.
bret
Level 3
Level 3
this is an old post, but wanted to add a comment. I had this same exact issue in my router logs and was not able to confirm if it was seated right or not. I ran a clear service-module serial 0/2/0. This command restarts the card and then loads the software again for the card. The state of my card before running the clear service-module was up/down. after running the command the card went down/down then up/up. Thought this would be useful info the next guy.
mmason221
CSCsw63356 is identified in the 38xx chassis, but rather confident 28xx bug as well.
CSCte08720
Symptoms: %SERVICE_MODULE-4-WICNOTREADY: Unit Serial0/0/0 is not ready for next command, "show service-module" counters are not accessible. In some cases the interface will remain down/down.
Conditions: This symptom occurs when HWIC-1DSU-T1 or WIC-1DSU-T1-V2 is installed on a system that is running one of the following Cisco IOS Releases: 12.4(20)T4, 12.4(22)T3, 12.4(24)T2, 15.0(1)M2.
Workaround: There is no workaround.
Had same issue on a 2821. Upgraded IOS and no issue since.
Jul  2 21:04:06.193: %SERVICE_MODULE-4-WICNOTREADY: Unit Serial0/2/0 not ready for next command,  -Traceback= 0x40421500z 0x404215B0z 0x40422820z 0x40422A64z 0x40423488z 0x404183ECz 0x405F7D68z 0x405F7784z 0x4042B274z 0x4042B394z 0x42EA5F80z 0x42EAB578z 0x42E99398z 0x42EC7930z 0x430C3E20z 0x430C3E04z
XXXiR01#show flash:
-#- --length-- -----date/time------ path
1     57973000 Dec 06 2012 16:26:34 c2800nm-spservicesk9-mz.151-3.T4.bin <-- new IOS
42    50862412 Jan 14 2010 17:40:08 c2800nm-spservicesk9-mz.124-24.T2.bin <-- old IOS
show hardware
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 15.1(3)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 24-May-12 01:38 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
XXXiR01 uptime is 1 week, 10 minutes
System returned to ROM by reload at 13:01:09 UTC Wed Jul 3 2013
System restarted at 13:03:07 UTC Wed Jul 3 2013
System image file is "flash:c2800nm-spservicesk9-mz.151-3.T4.bin"
Last reload type: Normal Reload
